Septic System With Or Without Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-23-2013, 11:04 AM   #1
Rewards Points: 159
Septic System with or without pump
Based on the contour of my land I need to make a descision on my septic location.
If I keep the tank and leach field close to my house I have sufficicent slope for my perimeter drain. BUT it is now too close to my well.
I would need to pay to move the well to the front yard.
OR I can move the tank and field slightly away from the house.
But I would have to pump from the house to the tank.
Installer told me $1,500 for this option. Which is cheaper then $3,000-$4,000 for the well work.
Any suggestions? My first thought was move the well... Since it is a one time cost. Not sure what the ongoing cost is for a pump..
theedudenator is offline   Reply With Quote
Old 07-23-2013, 11:09 AM   #2
Rewards Points: 1,952
Don't you have some local state official that is the authority on your septic system? Perhaps your local health department or state EPA. I would not do anything until they look into the manner and tell you what you can do.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
jmon (07-23-2013), joecaption (07-23-2013)
Old 07-23-2013, 11:10 AM   #3
47_47's Avatar
Rewards Points: 58
Waste water only into the septic. What perimeter drain do you mean?
I would want a gravity only septic system.
47_47 is online now   Reply With Quote
Old 07-23-2013, 11:26 AM   #4
Rewards Points: 159
I am doing what the local county is telling me.
Move the well, or pump the septic.
The permiter drain is a county requirement to keep ground water from entering the field.
Installers are telling my pumps are common and used all the time.
But in my head I think all gravity is better.
The Following User Says Thank You to theedudenator For This Useful Post:
47_47 (07-23-2013)
Old 07-23-2013, 04:11 PM   #5
Rewards Points: 37
Move the well.
Pumps work & they are installed all the time, but they do break.
If you are pumping from the house to the tank you will need a grinder pump & all kind of stuff stop them from working like baby wipes & female products.
You can say you will not put that stuff down the drain, but every system that I fixed because of people putting stuff down the drain that they are not suppose. They all said before I pulled that stuff out that they don't do that.
So move the well & pump your tank every (3) years & worry about fixing something else around the house.
TOOL82 is offline   Reply With Quote
Old 07-23-2013, 05:43 PM   #6
Civil Engineer
Rewards Points: 4,778
I have a pumped septic system. The first pump lasted almost 20 years. I doubt I will get 20 from the replacement, made in China pump, but perhaps ten is not out of the question. Cost me about $2000 to get the tank pumped out, and replace the pump and float. Your cost will vary, depends on location etc., but $2000 for replacement is not unreasonable. Trust me, this is NOT a job you want to DIY, unless you really know what you are doing. Confined space entry, toxic gases etc.
If you get ten years out of the pump, you can compare that with moving the well. You also need a pump chamber with a pump, make sure that is figured into the cost of the system by the installer.
One little detail is that a pumped system works better in many cases than gravity, since the pump provides positive head to encourage the effluent to flow evenly through the distribution box, whereas in a gravity system, even slight shifting of the distribution box can make one or more of the leach field pipes fail to function correctly. So my take is a pumped system is likely to work better than gravity, hence the field should last longer.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
MTN REMODEL LLC (07-23-2013)
Old 07-23-2013, 06:11 PM   #7
Rewards Points: 159
Just to clarify, the pump is after the tank to the leach field.
So there should not be problems with debris?
Not sure why a pump would be more efficent, never read anything like that.
Old 07-23-2013, 08:23 PM   #8
The guys a civil engineer I would take his word.
Old 07-24-2013, 06:52 AM   #9
Rewards Points: 3,130
In my experience, you usually have a lot more leeway in where to put the well than you do the septic system. In fact, where I live, being in the Chesapeake Bay watershed, there's no septic leeway at all. The Health Department tells you exactly what type and size of system to install, and exactly where to put it. The only restriction on the well (I think) is that it has to be at least 100 feet from the septic field. There also has to be a designated 10,000 square foot area on the property for a "septic reserve" in case the original system ever fails. Nothing permanent can be built in that area. Because of these relatively new requirements, there are now dozens of vacant mountain lots around here that can't be built on because they're too small.
septic pump for basement toilet denemante Plumbing 4 02-13-2013 10:42 AM
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 07:48 PM
Gurgling toilet - septic system wenwil Plumbing 2 11-18-2011 06:16 AM
problems with Grundfos UPS 15-42F pump and my boiler heating system Hexar HVAC 21 10-31-2011 04:44 PM
How does this sump pump system look and how would I add a battery back up? Jay Nel Plumbing 4 07-22-2008 03:48 PM
