Old 11-18-2008, 04:52 PM   #1
Default Septic/sewer pipe replacement
Hello,
I have a septic system and when I bought the house three years ago I had to have the sewer pipe from the stem wall of the house to the septic system replaced. The pipe that was replaced was terra cotta and had disentigrated due to roots.
The sewer pipe from the drains in the house go under the basement slab and now has roots in it as well. I used a video inspection system and located the section of pipe with the roots. This bad section is near the stem wall (where the outside pipe was replaced) and extends into the basement about three feet. I read somewhare that houses of my vintage (1986) frequently got bad patches of cast iron pipe from China, thereby possibly explaining why one section of pipe was bad but not the rest.
I talked to a plumber and he wants $13K to fix it. This is outrageous IMHO. So, onto my questions:
1) Can I use a locator to mark on the basement slab where the pipe is, concrete cut it, expose the pipe, and add a new section?
2) Do I have to use cast iron pipe or can I add a plastic section to join with the existing cast iron and the new plastic pipe added outside the house?
3) I am having trouble finding replacement sections of 4" sewer pipe; where should I be looking?
4) Once the pipe section is replaced do I just back fill the trench with gravel/sand and then pour concrete into the saw cuts (with expansion joints)?
5) What is the proper pipe slope?
Overall I am very handy and have most of the tools and can rent the rest. I would be happy to pay a plumber for some of this but the rates are out of my budget. Any halp/advice would be greatly appreciated.
Jeff
Mendocino is offline   Reply With Quote
Old 11-20-2008, 08:54 PM   #2
Yes, you can use a locater to find bad section. Find bad section, cut out bad section of pipe, take measurment of cut out section, subtract half an inch, buy pvc at lowes, homedepot(doesn't matter), i think they only sell 10ft lengths, also buy two "no hub bands" same size as pipe being replaced, they might also sell "Husky Bands", there a little bit more expensive but they hold up better, slide them on each end of new pipe, then take the pipe and place in the gap you have cut out of old pipe, then simply slide bands half way on to old pipe, tighten both bands. 4" pipe requires 1/8" per foot of fall, 3" pipe=1/4" of fall same with 2" and 1"1/2.
zosoplumber is offline   Reply With Quote
Old 11-21-2008, 02:09 PM   #3
Thanks for the follow up Zosoplumber. Much appreciated. Do you have any advice on the backfill and concrete pour?
Old 11-21-2008, 03:36 PM   #4
Back fill hole with gavel and pour 3-4 inches of concrete to fill in missing slab. NO expansion joints.
Old 11-21-2008, 07:40 PM   #5
Thanks Joed
More On This Topic
Ok. We're outside the house now. We're going to talk about where we tie these to the existing sewer line. And, you remember that we had Arizona Blue State come out and mark the ground on the street to give us an idea of where this sewer line is. Where it... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. One thing to remember when plumbing your basement, is that the location of the toilet is not as important as it first may seem. Where that pipe is sticking... Read More »
Hi, I'm Jeremy Blackwell I'm here today to help you get started on your basement remodel project. This is a GFCI outlet that's required in bathrooms. The reason this is required is because if any water were to just drip on the outlet or if a hair dryer... Read More »
Before you buy a house, it is a good idea to either inspect it yourself or hire a professional to do it for you. If you do not know what to look for, you may end up with repairs and problems you did not expect. Here are some tips on how to inspect... Read More »
Once you get all of your plumbing in. Now on this sink, the drain is set forward from the drains coming out of the sink because of the remodel. This inlet right here is going to go to the dishwasher on this side of the sink. We had to use a flexible hose... Read More »
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 07:40 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 01:55 PM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-22-2008 01:48 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 05:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 01:09 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
