Septic Pump Runs Constantly - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2010, 07:28 PM   #1
I'm buying a house, and for the past 3 weeks that I've been looking at the house, the wastewater pump between the house and the septic tank has been running continuously. I had an inspection, and they said it's working perfectly, but I talked to two neighbors that have the same type of system (same builder for all the houses), and they say their pumps cycle on and off. Any ideas before I close on the house what the problem could be? Thanks!
GAjamie is offline   Reply With Quote
Old 01-14-2010, 09:09 PM   #2
My system is all gravity fed, although I have a second system for a back shop that is on a mound/pump. It does not run all time. I am assuming that the pump is in a pit of some type and is taking on water? Maybe there are kinds that run continually.
I'll be back with plenty of septic/drain field questions of my own, in the near future, like in the spring.
Hopefully someone else will reply.
Bill
Bill7 is offline   Reply With Quote
Old 01-14-2010, 09:27 PM   #3
You need to get this resolved before you close on this purchase of the house. The septic pump should not be running constantly. They normally run when the pit gets to a certain level and they put a measured dose into the field.
If this continues I think you can look forward to two things --
1) high light bills until
2) pump fails and it needs replacing
meboatermike is offline   Reply With Quote
Old 01-15-2010, 06:27 PM   #4
Thanks for the help.
Tags
runs continuously , wastewater pump
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Jet Pump runs continually Jimbobwe Plumbing 2 08-04-2009 12:25 PM
ejector pump running constantly??? streetwise83 Plumbing 1 09-13-2008 08:37 PM
