Septic Pump Running Every 10 Minutes For A 2.5-3 Minutes - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2013, 01:18 PM   #1
Rewards Points: 201
Septic Pump running every 10 minutes for a 2.5-3 minutes
We've had some rain the past day and a half, some of it heavy.
I have a TED5000 power meter installed as I like to monitor the home's power consumption. Over a 12 hour period, I noticed many very small blips in a consistent manner. They occur every 10 minutes and last between 2.5 and 3 minutes and draw about 1.2kW every time. There is an inrush current that will spike show a quick spike of 1.8kW before it settles at 1.2. I had no idea what was happening, so I started flipping breakers until it dropped, and it turns out to be the septic pump.
Our septic system has a main tank and then a small 200-300 gallon holding tank before going to the drain field. I believe this is the pump that is running, but would a saturated ground be causing this level to fill up or am I more likely to have a fault float?
Thanks.
phuz is offline   Reply With Quote
Old 01-31-2013, 01:31 PM   #2
Rewards Points: 1,492
Is the field higher than the septic tank? Could water from the field be falling back into the holding tank when the pump has shut off? Can you open a hatch and see what is going on inside the holding tank?
Old 01-31-2013, 02:41 PM   #3
Rewards Points: 610
Also, surface water could be entering the top of the tank, via the clean out lid(s), if not sealed correctly.
techpappy is offline   Reply With Quote
Old 01-31-2013, 03:35 PM   #4
Rewards Points: 201
Water is flowing back into the pump tank after the pump shuts off. The top of the drain field (which is higher than the tanks) has visibly flowing water. The water appears to be entering the tank from the pipe, though.
This only started happening within the past 48 hours.
Old 01-31-2013, 03:55 PM   #5
Rewards Points: 13,446
One of the first signs of a failed leach field is water running back into the tank.
Old 01-31-2013, 08:08 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 994
no running toilets ?
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
well pump pressure without the prime plug? sawduster Plumbing 11 12-19-2012 05:48 PM
Good Pump For Septic - 70 horizontal feet JohnSlider Plumbing 2 01-03-2012 08:20 PM
sump pump keeps tripping breaker after about 5 minutes of running DanDaMan Electrical 9 04-21-2011 11:32 PM
Dry sump pump pit/failing septic system Jenn M. Plumbing 4 01-08-2010 09:01 PM
running the sump pump to the sewer line Jack Hass Plumbing 9 11-02-2006 09:36 AM
