Septic Pump Issues - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-11-2010, 09:51 PM   #1
septic pump issues
I believe my septic/sewage pump suction pipe has a leak in it as the pump does not stay primed for the discharge to go to the disposal field. How do I know or find out if this is the case and how do I fix this leak? All the the piping is under concrete and I hope I don't have to dig it all up.
klyrocks is offline   Reply With Quote
Old 10-12-2010, 08:24 AM   #2
check the check valve. make sure it's fully closing, then drill a 1/8" hole in the pipe between the pump and check valve. This will prevent the pump from becoming air locked.
the_man is offline   Reply With Quote
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 01:04 PM
Sump pump issues GeorgeHuhges Plumbing 3 10-19-2009 02:43 PM
power steering pump replacement issues joey219 Automotive Repairs 2 10-08-2009 03:14 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
