-   -   septic pump issues (http://www.diychatroom.com/f7/septic-pump-issues-83676/)
klyrocks 10-11-2010 09:51 PM
septic pump issues
I believe my septic/sewage pump suction pipe has a leak in it as the pump does not stay primed for the discharge to go to the disposal field. How do I know or find out if this is the case and how do I fix this leak? All the the piping is under concrete and I hope I don't have to dig it all up.
the_man 10-12-2010 08:24 AM
check the check valve. make sure it's fully closing, then drill a 1/8" hole in the pipe between the pump and check valve. This will prevent the pump from becoming air locked.
