Septic Odor From Washer Machine Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2012, 10:53 PM   #1
TMC
Septic odor from washer machine drain
I have a septic system that is running properly however when my kids take a shower an odor is emitted from my washer machine drain. Is there a way to seal the drain making the drain air tight and still have a functional washer drain?
TMC is offline   Reply With Quote
Old 02-01-2012, 11:00 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Is the line for the shower vented?
Sounds like it could be sucking air through washer stand pipe emptying out the trap
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-01-2012, 11:00 PM   #3
Missouri Bound's Avatar
I'll assume your washing machine drain is a standpipe which your hose is stuck into. You can't seal that connection because air needs to flow around the hose to break any siphon action which could occur and would drain your washing machine when it's supposed to be filled. Is this a newe issue or was it always like this? There should be a trap at the standpipe which would prevent any sewage smell from coming from the pipe.
Do you want it your way or the right way?
Old 02-01-2012, 11:01 PM   #4
Rewards Points: 13,260
That drain is suppost to have a trap in the line (may be behind the wall)
There is no trap then there's going to sewer gas going into the house.
Old 02-02-2012, 08:40 PM   #5
Rewards Points: 582
as mentioned is this a new issue ..could be maybe lint building in line and shared with shower causing it to syphon trap???? no you should not seal off hose tight..
Building a Washing Machine Drain Pan wiz561 General DIY Discussions 8 04-03-2011 03:51 PM
Problem with Washer drain StephenM Plumbing 1 04-01-2011 06:37 PM
Washing Machine Drain Pipe tjeieio Plumbing 2 02-25-2010 06:19 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 11:35 PM
Sink doesn't drain into Septic but somewhere else? 40s house? Where? twilightcall Plumbing 11 01-18-2008 09:36 AM
