Septic Floor Drain Trap Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2013, 07:35 PM   #1
Septic floor drain trap question
I have to remove the current set up to allow me insulate the wall. What Iam attempting to do is have a straight run of 3 inch PVC pipe straight into the trap. Once I remove the old PVC should I replace the trap with the same PVC fitting. I've seen at the plumbing supply that there is a 3 to 4 inch rubber seal that gets put into trap and the 3 inch pvc pipe slip into it. Not sure what the correct set up is?
dontilgon is offline   Reply With Quote
Old 03-13-2013, 07:39 PM   #2
Second photo
Old 03-13-2013, 08:08 PM   #3
Rewards Points: 14,312
http://www.fernco.com/plumbing/donut...e-pipe-gaskets
Old 03-13-2013, 08:56 PM   #4
Thanks joe , this is the rubber seal I was talking about. Is it safe the say the current set is wrong? Also is there Sealant that needs to be applied. Thanks
Old 03-13-2013, 10:41 PM   #5
Lord of Slums
Rewards Points: 1,974
they make a slip joint coupling in pvc. you could cut the pipe and re glue the coupling in,not mess with that current set up just for insulation
mj12 is offline   Reply With Quote
Old 03-13-2013, 10:46 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 910
To add to this- you should have clean out at the base of the stack too- use a wye or a clean out tee.
Old 03-18-2013, 08:14 AM   #7
Thanks guys for the quick help. The Fernco seal fit/worked perfectly. I do have clean out to the right . Thx again
Septic - Future Nightmares scootermcrad Plumbing 6 12-04-2012 07:47 AM
Connecting brass trap to cast iron (Noob) acr2001 Plumbing 7 08-22-2012 12:37 AM
question about vent stack firstimereno Plumbing 7 05-22-2012 10:47 PM
septic question countrygal2012 General DIY Discussions 9 05-15-2012 03:35 PM
Drum Trap Replacement RickyBobby Plumbing 4 02-28-2011 06:59 AM
