Septic Field Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-06-2013, 04:01 PM   #1
Septic Field Vent
My septic system is not gravity fed, but uses a pump to move the liquid up into my drain field. There is a J-Pipe vent at the pump end of the field, but there is also a 4" diameter pipe sticking out of the ground at the other end of the field.
This 4" diameter pipe is cracked and I need to replace it. If I dig it up, will I find that it's connected to piping underground or is it just inserted into the ground? It's only sticks up about 6" above grade....should the one I replace it with be higher?
Thanks very much for your help.
Mart
mega44 is offline   Reply With Quote
Old 07-06-2013, 05:21 PM   #2
Civil Engineer
Rewards Points: 4,522
If the pipe is simply stuck in the ground, it won't be doing much for your septic system. Most probably it is connected using a Tee to the 4 inch piping in your field. Simply replace it with a similar sized plastic pipe. My pipe sticks up about 3 feet above grade, local practice varies.
Old 07-06-2013, 06:53 PM   #3
Rewards Points: 3,130
I had the same thing. We have four laterals that originally had such a pipe at the end of each one. I asked the installer what they were for, and he said they were inspection points. He also said, off the record, that once my system was approved, I could get rid of them. I did.
septic vent rc1985 Plumbing 6 08-23-2012 01:46 PM
frozen septic field r.mills Plumbing 2 03-01-2012 11:17 PM
How do i fix/install septic tank drainage field? vcordon Plumbing 10 06-15-2010 11:20 PM
Air admittance vent with septic system. Roy Rowlett Plumbing 4 06-14-2010 10:53 AM
Septic Efluent Leach Field Docfletcher Plumbing 9 01-10-2010 08:47 AM
