Septic Field Diverter Valve - Which Field Is Which? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2013, 10:05 AM   #1
Rewards Points: 302
septic field diverter valve - which field is which?
Hey all - see my attached sketch. I have two septic fields with a diverter valve. But I can't figure out which field is which.
In peering down the riser tube, the valve head is a rectangle shape. I've got a long rod with a T on top and a small U on the bottom.
Using the picture as reference, the valve head only turns 1/4 turn. So it would either be aligned north/south in the picture, or turned clockwise and be positioned east/west. Go counterclockwise 1/4 turn, and it's back to north/south.
I'm wondering if the flow would go the same direction as the head is aligned. So based on the sketch, if the valve head was north/south longwise, it would flow to the old field.
I'm not just familiar with valve types. Perhaps if the valve was north/south longwise, the flow would be through it east/west - and in my case, that would be to my new field.
denemante is offline   Reply With Quote
Old 01-16-2013, 10:46 AM   #2
DIY staff
Rewards Points: 7,174
I believe you are correct---the flow typically follows the alignment of the slot or T-handle coupling.
frozen septic field r.mills Plumbing 2 03-01-2012 11:17 PM
septic field line question Lightfoot Plumbing 6 05-08-2011 02:24 AM
Septic Drain Field ekulrenlig Landscaping & Lawn Care 16 04-27-2010 10:59 PM
Buried wire through Septic Field Moose50000 Electrical 2 03-14-2010 11:16 PM
Need help replacing shower diverter valve magnolia Plumbing 9 07-12-2008 10:54 PM
