I have a septic problem and a load of family coming in for the holidays - please help!
We have a septic tank and drain field. The previous owner had an entire second drain field installed with a diverter valve a few years ago. I asked him why, and he told me because it lets one rest. That seemed strange to me - why not then just leave both on?
We've lived in the house 8 months. While in the finished basement after a day of heavy rain, I heard loud "burbs" coming out of the basement toilet, with a slightly foul oder. I panicked of course, and got a septic specialist out. He said I'd need to put something in there to eat it up which might buy some time - or replace the fields (I ended up doing nothing and all has continued to work fine until now).
I called my city. I got copies of the actual septic work that was done in 2008. Along with them came back the original septic field and system layout.
I called the guy who did the new work. He said a "dual system" with a diverter valve was the best way to go - and everyone should do it - if you have the money. He said to switch it about every year. So I'm working one drain field for a year - and another for a year, etc.
OK - so I went outside with a long water main post/tool, found that valve and "switched fields". This was about a 1.5 months ago. I have no way of knowing which field I switched it to.
Now I've read a lot about septic - and did hear that if a field gets inundated - you're screwed. But this guy swears that a year of leaving it alone, even if it's not working right - will most likely allow it to rot away and you can use it again in a year. I saw the receipts - the previous owner paid this guy a lot of money, and he continues to be reputable around town. He also told me that septic isn't perfect. If you have heavy rain for example, you may have some issues likely in the basement, etc. But things should go back to normal if you care for the system.
Now today - we've a problem. I tried to flush the basement toilet and it almost overflowed (clear water). My wife did do a ton of laundry today, and by concidence, we and the kids all had showers/baths. But even during that heavy rain when the basement toilet kept "burping" - it just wouldn't flush - it didn't act like it was clogged and start to overflow.
Worse - I went to our first floor bathroom. I flushed - and it too nearly overflowed. We haven't really had much rain at all recently, if any in the last few days. But I did notice the ground in general everywhere seems moist. So perhaps the (Atlanta) weather is keeping moisture in the ground.
Worth mentioning is that the water in the toilets did go down after a short period of time.
SOOOOO......I'm thinking this is one of four possibilities:
1. I'm screwed. The whole system is jacked and I need all new fields.
2. I'm OK - this is just coincidence that we used a ton of water today and flooded the system, and tomorrow everything will be OK.
3. The "diverter" - when I switched it 1.5 months ago, I switched to the old field which perhaps was jacked and never purged itself. So I should switch back.
4. The septic tank is full.
Any thoughts here? I know there are a lot of possibilities. But I have very little time and I've got to make an informed decision ASAP!
Worth mentioning again is that I confirmed my wife did about 6 loads of laundry and everyone took baths and showers today, and we ran the dishwasher a few times - and the ground is a little wet.
It sounds as though the system is overly saturated. I don't believe it's a ventilation problem.
How often do you have the tank pumped or have you ever?
Does the schematic you received from the county or health department show or tell whether the drainfield consists of perforated PVC, or is it comprised of infiltrator chambers (graveless system)? How many legs are in the leachfield? What size is the tank? Is it single or dual chamber?
A Terralift is a machine that; with hydrolics, drives giant rods into the ground, builds up pressure, then blasts polystyrene beads and air into the soil. Thus, breaking it up and rejuvenating it to allow the effluent to once again "leach" as it should. I have seen amazing results from terralifting drainfields. It's far less expensive and less intrusive than the installation of a new drainfield. Their website includes a map to find authorized service providers. I would suggest you check into it.
its all hearsay until you look in the septic tank. If its full to the very top, its a drainfield problem. If its at normal level (which is at the same level as the outlet pipe) its either an inlet baffle or a drain problem. Get that shovel out, dig it up, and tell us what you see :yes:
the septic tank is full but full of what? It will always be full (at least full up to the drainage port) with fluids. It's when it becomes loaded with solids or scum that you need to do something and that would be pumping it out or as the_man said, if it is filled beyond the outlet port.
Was is pumped when you bought the home? I know in my state it is a requirement but others apparently do not require this. If it was pumped at purchase, you shouldn't have been able to fill the tank with solids in 8 months. It generally takes years.
You shouldn't be able to run too much water (unless you just turned on the water and let it run day and night) to cause the field to back up if it is working half way decently.
what is the make up of the ground in your area? If there is much clay in the ground or rock?
UPDATE: When I first noticed this problem in the basement toilet - I tried plunging it. I could hear noise out of the sink next to me. Then I went into another room where we have a little wet bar - and a little water had blasted out onto the counter/floor.
ALSO: I looked in the top floor toilets - and the water level was down in them. That's weird to me - I thought water couldn't leave them unless you flushed it away. I mean - if a 3PM everthing was fine and the toilets refilled the bowls to the normal level, why would they be "low" at 12AM? Or - perhaps they didn't refill fully after being flushed and I didn't notice - but that would be a water line-into-the-house problem.
We live in Geogia. The forms I got from the county about the permits when the work was done note the soild as "Hiawasee".
When I first noticed this problem tonight, in the basement toilet - when I flushed it - it "burped" and spashed water out. A friend who is an inspector once told me that's a vent problem.
In the basement at least, we have those in-house vents. They are PVC pipes capped with this little vent cap. I know some go out the roof in some houses. But mine appear individual on the basement plumbing, but I can't speak for the rest of the house.
Can you elaborate on how could a vent problem be the cause, and what I might do to fix it?
the low water level in the bowl could/would be indicative of a vent problem. While normally air is allowed to flow behind the stuff in the pipe from outside, if this is blocked, there will be a vacuum created in the drain pipe. This can draw water from your toilets and traps.
How tall is your house and are you adverse to climbing on the roof?
I'm willing and capable of troubleshooting anything here even on the roof - thanks for the suggestions!
I understand the premise of venting. You can't easily take an empty bottle of water and try to quickly dump a full bottle of water into it. The air escaping needs to go somewhere. Our home was built in 1998, and the basement finished in 2008 (some is still unfishished, so I can see behind the scenes a little). We have at least two of those vent-cap PVC pipes in our basement. For the upper floors, I don't know if in 1998 they would have vented out the roof.
But maybe I'm talking about the wrong thing. Maybe every drain/toilet is vented, but there's also some master vent and perhaps that's where the problem is?
So if you flood it - there just isn't anywhere for anything to go. So if I wait, things will purge and I'll be OK. People who have lived in the neighborhood had said similar things in the past.
But perhaps I've identified a vent problem I didn't know existed - water and waste is high in the system and perhaps air is trapped too, but if the air can't escape the vent to allow the waste to move in, then I've got a bottleneck?
wow, 12 years old and needed a new field already? That in itself suggest you might have some problems for drainage regardless of a venting problem.
I do not think there is such thing as a cheater vent being acceptable for a toilet. (yes, I know they have a real name, just can't remember what it is called).
The first thing I would do is look for roof vents. Then, have a plumbers snake?
and hopefully the actual plumbers can comment on this but it sounds like your cheater vents are hidden behind a wall or something. I was under the belief they had to be accessible.
My guess on the disappearing water is when you were plunging the lower level toilet, it created enough vacuum to draw water out of the upper level toilet.
Assumption is that your basement toilet is above the level of the septic tank, if not you must have a pump in the system.
Assuming you don't have a pump ---
I would bet that both upper and lower vent to the outside thru the roof, without further info we don't know if its through the same stack.
But assuming it is you have one of three scenarios:
1 - Your vent piping has been plugged by who knows what, careful reaching in on the cranky critters.
2- Your drain piping is plugged with who knows what (call roto rooter)
3- Your system can't take anymore and has gone on strike.
Check
Vents to ensure they are clear
Call roto-rooter to ensure drain is clear
Check stink tank to ensure its not packed with dodo.
The basement toilet is above the tank - so no pump.
In response to NAP - yeah, 12 years old (10 at the time) and the previous owners had a second field put in. The original remains, and in use when I turn the "diverter valve" to it about once a year.
My memory is vague - but I though there was mention that they had "septic system increased in capacity" because they finished the basement and added a bathroom. However - they didn't add any new occupants to the home - so the home usage of the system should have been the same, right? They did entertain in the newly finished basement, so perhaps that was the thought process - that there would be increased volume from friends.
So I don't know if the old system was bad, but still good enough to leave intact yet add this secondary field to it, or if that's commonplace.
Maybe it's cheaper to just leave the old field and install a new one if you have room - and while you're at it - just toss in a diverter valve (maybe that's even code) so the old (totally bad) system can remain and all can save on shovel-labor.
I mean, according to the guy who installed the secondary field before I was the owner, he said it's a great way to go.
Even if it's not and the old field is shot - forget about it. I have the new field from 2008.
But NAPs post begs the question: if field #1 did go bad in 10 years and field #2 was then installed by the previous owner - perhaps the ground/drainage is bad. But I can't move my house. So then what?
the size of a field is generally determined by the number of bedrooms and bathrooms regardless of how many people actually live in the home. It is designed to utilize the bath/bedroom count to determine a max occupancy.
let's hope that the only reason he did enlarge the field is due to the added finished living area and not due to the failure of the field. What the septic guy said does suggest it might have been due to a failure though:
I've never seen a diverter valve for a septic system, so I have no idea of what it looks like. I'm very familiar with many types of other valves though. My thought is: How would one know when turning the diverter valve if it is open to which septic drain field, or if it may even be partially open? I'm wondering if this valve may not be fully open to either drain field and is not allowing full flow of waste water from the septic tank and creating a back-up of waste water to the home? I am somewhat familiar with the Atlanta area also, my sister is a realtor up in the NE area. What would it cost to have a company come out immediately and pump the septic tank dry? This could tell you two things-how much liquid they remove vs. the tanks' working capacity, and this would give you the tank's working capacity for the holiday period.
Well, my past post was last night after midnight in the full thows of the problem. But at 9:30AM, I went down to the basement and flushed. Back to normal - it flushed fine. Obviously, I'm watching everything carefully.
This would lead me to believe that it was flooded from all the heavy water use yesterday, and has now settled out.
Still, that's not ideal, but perhaps that just the quirkiness of my system. I've read other posts where people had similar issues they just work around.
Even so, I have no idea when the previous owners emptied the tank. So perhaps now is the time to do it so I get a fresh start, perhaps some feedback or info from them, and at least 1000 gallons of time throught he holidays...
Hey all - the oririnal 1998 permit for when the house was built notes the soil has a perc rate of 40 min/in., the tank is 100 gallons, the apsoprtion field area is 1140 square feet, 380 linear feet, trench width of 36, and trench depty of 55. It is an INFILATRATOR system. Level of plumbing outlet is basement ,and field layout method is listed as serial distribution. Soil type hiawasse.
A hand drawn attachment shows the fiels in a wide S shape, and what looks like segements to it, with notes saying 11, 12, 7 matching the drawing (as in segments along the three field lines.
The 2008 new system shows a second field and diverter value out behind the original, and one note says "divert surface water". There were french drains installed in the back yard which pour into a ditch in the extreme back corner of my home.
I just talked to the designer of the system who sais he thought it was over saturated, or perhaps the original drain field (that I must have switched to when I turned the diverter value) isn't purging the system as well as the new drain field.
So he said to just switch back to the other field.
I decided to have the tank pumped, and a guy came out this AM. But the price went from $200 to "$1100 or $1200". He said he'd have to dig more than they thought, and then would "jet out" various elements.
So I sent him away. But he asked if I was handy. He said I could dig down (and he showed me where), and said to remove the cap on the septic tank and look in. Then, and only then - I could switch the diverter valve and I should see stuff flowing into that field. He basically implied this would tell me that the one field isn't purging water, and the other is OK. He said I'd see stuff rushing into that field - I guess through the little cap I remove on top of the septic tank?
But I also figure I could just switch the valve, and go flush toilets. If they work, I'm good.
All this - and perhaps the field that's turned on now is simply oversaturated from putting too much water in yesterday.
So perhaps if I ignore this all, leave it on the fields it's already on, and be more careful with water use, I'm OK.
If you're getting clear water coming back, then a jetter won't do anything. Nor will it remedy a saturated drain field.
You mentioned you had a full basement. That means the system is deep. Deeper than you'll want to dig by hand. Most likely will require equipment (back-hoe). When the system was originally put in, were there risers installed over the septic lids? How about over the distribution box?
I'm not sure what risers, septic lid, or distribution boxes are. The guy who came out this morning (who I sent away) probed the ground in front of me with a stick. I already knew where the tank was and showed him. And I watched as hit hit the top, and found the edges, and drew in the grass where the tank was. And in the area he showed me to dig - the stick went down about 2.5 feet. So that's how far down I'd have to dig (by hand). But he had a small backhoe with him I think he was going to use.
Right now, my main concern is simply getting through the next 10 days - the forcast shows little rain.
UPDATE: I mentioned that this AM, after 8+ hours of no water going into it, I was able to flush the basement toilet as usual - so perhaps the system did purge a bit. But now at noon - the problem is back - basement and first floor toilets won't flush.
It would seem my fastest and best solution would be to switch drain fields and go back to one that always seemed to work fine. And probably, get somebody out to pump the tank who won't try to sell me $1000 more in fixes that may or may not work.
My gut is telling me that my system simply cannot purge water fast enough. The rising water in the toilets is clear. So as suggested, the overall problem might be with my soil - not any backup or clog or failing of anything. If that's true - then I've got to look at the solutions suggested here - but that is not something I think I'd jump on today...
If you really want to get a decent night's sleep, I'd certainly suggest digging the cover/tank out by hand. This site can't clear up all of the speculation, but witnessing the tank level, and having it pumped, certainly can................... :yes:
Most service plumbing companies will try to sell more work. They don't make money pumping septic tanks, running cameras, or snaking lines. Once they're on site, a "quality" service plumbing company will discuss "options" with you, better educate you on the problem, and provide you with the best possible solution without aggressive sales tactics. In your case I would suggest, just as you mentioned; switch back to the other drainfield, and have the tank pumped to buy yourself some time over the holidays.
In my area average pricing to pump a 1000 gallon tank is about $315. A quick search revealed this ad from Mr. Rooter. $195. Sounds like a good deal to me. You may want to call them regarding the small print. Mr. Rooter franchises typically have all the equipment for servicing, repair, replacement, pumping, rejuvenation, etc. Keep in mind however they are all independently owned franchises. Some are ran very well. Other aren't. I personally don't know anything about the franchise in Atlanta. In my original post I also left a link for Terralift International. I noticed a septic pumping company listed on there. You may want to check with them also. http://www.mrrooteronline.com/
Also if he only probed 2.5' to find the tank, that indicates there's some type of riser over the lid. If you decide to dig it up, I would also suggest adding risers to bring it to ground level. That would make it more serviceable in the future.
UPDATE: I just went out and switched the fields. Since the diverter valve is in fact in a riser to the surface, I use a long water valve T pole to do this.
Immedidately after I turned the valve, I put my ear to the metal T-pole which is still on the valve. I could hear liquid flowing - which is what I had hoped for at least for now - I listened for a minute or so and it continued then I gave up listening.
I think this may be a clue. It would seem that the tank was high/full and for whatever reason field A wasn't purging. And my toilets were backing up.
Since I heard water flowing - I hope that was the sound of a fuller septic tank flowing out into the empty field B - (and not Field B full of water flooding my tank!)
I have no way of knowing whether I switched to or from the new field. But I hope I was switching from the old field (perhaps mostly failed) to the new one.
Worth noting is that while we haven't had much rain - the ground is saturated. And - when I looked down into the diverter valve riser (about maybe 3.5 feet down) I saw perhaps 2 inches of water on top. It was bone dry when I did this exercise 1.5 months ago. Maybe that's the water table or at least where it is today. Maybe that excess ground water combined with heavy water usage caused my probs with Field A.
In any event, I'm hopeful I've bought a little time. I'm feeling that the Terralift solution might be something I can look at after the holidays.
All sounds logical to me. Good luck and keep us posted on the outcome. I'm guessing since you switched to the other drainfield, your toilets are working again?
Yesterday night, basement and first floor toilets were backing up.
This AM - both flushed normally (presumably a little water purged overnight)
By noon - both basement and first floor toilets were backing up again.
Switched diverter valve at 1PM, then flushed the basement toilet about 10 miutes later and it flushed fast and normal, and the first floor flushed fine too.
I'm terrified, of course, that the toilets will start backing up again even on this new field. If that happens, then perhaps the first field was fine too, but both fields are simply inundated with ground water. OR - there's a stoppage between my house and the tank. OR the tank is full.
I'm just preparing for the worst in case I need to act fast!
While I'm at it - I should mention something else I've been thinking about. The previous owner had two french drains installed. The are green plastic grates in the grass near the back of my home and somewhat close to the original drain field. Piping goes to the backside of my property to a little drainage ditch. There, I can see two separate corregated plastic tubes coming out of the bank. I actually found two more of these along this drainage ditch - they appear to come from the gutter downspouts.
So these French drain pipes cross over both drain fields. With cooregated pipe, who knows how strong it is when buried.
In the summer, I noticed a horrible smell. I first though it was septic because the smell was similar. Then I realized it was coming from one of these french drains. With corregation on the plastic pipes, there are those little 1/2 inch ribs. Over a 75 foot run - they must hold a ton of water. It must rot and stagnate in there. I figured I could dump a jug of bleach into it, but was fearful of polluting the neighborhood or even eating away the plastic (since most of it would probably just sit in the first 2 feet). Or, if there happens to be a break in one of them - I was afraid I'd poison my septic system.
I stuck a hose in both. They drain really slow - but eventually, water does come out the ditch end. Somebody once told me corregated piping is bad - solid pipe is good. So I wonder if I have a break in one of those French drain lines - and if so - maybe it's dumping water into the septic fields vs. taking it away...
I have no way to tell. I was going to take a 5 gallon bucket and dump it in - and put another one at the other end. Then, I'd hope 5 gallons would come out the far end. But with all those little ridges in the pipe - I'm guessing very little would even come out the far end - it would all be caught in the pipe.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
