Septic Cracking - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-10-2011, 08:55 PM   #1
Septic cracking
This can't be good right? Not leaking yet. Not sure how long it's been like that. Found this when checking out a house to buy.
jgjh151 is offline   Reply With Quote
Old 08-10-2011, 09:56 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 672
Not good. Have them lower the price to cover repairs. And replace it with a wye- not a tee.
Old 08-11-2011, 09:32 AM   #3
surface issue
Could it just be a surface issue and the pipe could last much longer like that?
Old 08-11-2011, 09:35 AM   #4
Looks like a surface crack for now, but how long will it last? Who knows. Get it replaced, or the price lowered, like E Plumber suggested.
Also, how far away is the nearest pipe support?
VIPlumber is offline   Reply With Quote
Old 08-11-2011, 06:55 PM   #5
How much would it cost to have replaced? This is in update NY.
Old 08-12-2011, 08:22 AM   #6
Inspectors says around $500 to replace that piece.
On a side note, the guys inspecting the septic couldn't find the septic tank openings. They poked in the ground with a bar, found the box by digging a small hole, but said they would have to bring in a machine to dig more and find the openings. This sounds like a big deal to inspect the septic system. Don't they usually find the openings with a metal detector or digging a few more small holes instead of bringing in a machine a tearing up the seller's yard?
Old 08-12-2011, 08:52 AM   #7
Plumber
Rewards Points: 672
Hard ground, more then 2' deep-- dig with a hoe or have the home owner expose it. I'm too old to camp out on a shovel. Especially if I'm not sure I'm digging in the right spot.
The Following User Says Thank You to TheEplumber For This Useful Post:
VIPlumber (08-12-2011)
septic emergency? help! denemante Plumbing 47 11-21-2011 01:05 PM
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 06:35 PM
septic tank problems. littles Plumbing 1 02-24-2010 09:30 PM
Foul smell from abandon septic tank in house tsduncster Plumbing 12 12-19-2009 08:55 AM
Septic Newbie Needs Advice flyboy Plumbing 5 04-06-2009 06:05 PM
