-   -   septic - could you fill a 1500 gallon tank in 10 months? (http://www.diychatroom.com/f7/septic-could-you-fill-1500-gallon-tank-10-months-165845/)
denemante 12-07-2012 02:35 PM
Hey all,
We have 2 adults and 2 small children using toilets, bathing, doing wash, etc. Just normal use. Any way that a family like ours might fill a septic tank in just 10 months?
I've had ongoing septic concerns since moving in 3 years ago. My saga revolves around the basement toilet "burping". And it always does it right around Thanksgiving when the temp starts to cool in Atlanta. It burps when you flush it, it flushes slow, and bubbles when other water is used in the house - but still works. The problem goes away in about February or March.
Year one - I had some guys out and didn't like what they had to say. I did nothing. Problem went away. Used system with no issue for a year.
Year two - repeat. I had different guys out, didn't like what they had to say either. Problem went away. Used system with no issue for a year again.
10 months ago - decided it was time to have the tank emptied since it's unknown when the previous owner did. Tank was full. Filter fine, fields fine. Glad I didn't listen to the first two guys in previous years who wanted me to replace the fields, etc.
But there was a missing T-valve/pipe where the main drain enters the tank. It's just a L-shaped 8-inch piece of PVC that makes a right turn down into the tank about a foot. It wasn't there. So the main drain just came out horizontally into the tank about 2 inches. When the tank was emptied - it wasn't in the bottom. The septic guy had no clue why/how it was missing. So they added one on.
They also said that a patio the previous owner added over the main drain line had pushed it down a bit. So waste wasn't flowing strongly downhill into the tank - that line was nearly flat, so sewage could get stuck in that run of drain line.
Guy said to tear up the patio, or use a hose to blow out that section when needed. And double flushing and running water would help "push" the stuck waste through into the tank.
15 feet from the tank in the patio is a washout. I open it, and can see waste inside. So that main line must in fact be full or backed up.
I'm again experiencing the same bubbling basement toilet and burping from it. But again, in past years, I did nothing and it just went away.
1. I wonder if enough weight of waste backs up in the line and finally blasts that one section clear eventually.
2. Or, the tank is so full it's backing up into the main drain (when emptied just 10 months ago?)
3. Most of you might suggest the field may be defective or bad so the tank can't purge. However - I have TWO separate fields. Previous owner added the basement bathroom so somebody talked him into adding a much larger field, even though that might not make sense - he did it. So I have a diverter valve and switch the fields about once a year. The previous septic guys said I'm super lucky - my fields were fine (filter was also perfect) - plus I have two totally separate fields just in case.
Using common sense, it just seems like that main line is a bit backed up under the patio (since I can see waste in the washout), and perhaps trickles into the tank vs. flowing. Like I need a giant plunger or something.
Anybody have any thoughts here? Should I rig some sort of 8 inch round pusher on the end of a flexible rod, and jam it down the overflow to see if I can push the waste through and solve the problem?
cgoll 12-07-2012 02:55 PM
My water softener can display average daily water usage. We (family of 5) use about 160 gallons per day. We'd fill that tank in less than 10 days.
jbfan 12-07-2012 03:11 PM
Unless you are on a well, your bill should give tell you how may gallons they are charging you anyway.
2 people in my house about 3500 gallons plus a month.
denemante 12-07-2012 03:48 PM
I stated this wrong. I know the tank fills in a week or so. What I meant is, is there any way it might need to be emptied after just 10 months?
Since I know I've got some sludge in my main line that leads to the tank, I'm hopeful that I can just clear that out with a hose or roto-rooter. Just remove the growing stoppage.
But if what I see in there is overflow solid waste from the tank - then I need to have the tank emptied.
But since the tank was emptied just 10 months ago, that would lead me to think the tank is fine....and that drain line is a bit backed up.
mikey48 12-07-2012 04:00 PM
I would clear the line, sounds like the septic is working like it is suppose to. It will fill up to the outlet going to your drainfield. Crap goes to the bottom and gray water to the drainfield.
TheEplumber 12-07-2012 04:17 PM
199 Attachment(s)
You can use a blow bag down the cleanout. It will seal the pipe off and then release pressurized water to flush the line.
Have you confirmed the tank outlet is lower then the inlet?
If the system is properly installed-10 month is too soon to pump
TOOL82 12-07-2012 04:25 PM
Your tank should be pumped every 2 years. The "T" they installed should be installed on the outlet side. Your drain line needs to slope a 1/4" per foot. Sounds like your drain line has a slope problem or roots. Have a drain cleaner come out clear the line & put a camera thru the line to check for problems. Make sure he gives you a copy of the video (no video no pay), or you can buy a power snake & snake the line out everytime you have a problem. You should have a cleanout inside the house. If not remove the basement toilet & snake from there.
joecaption 12-07-2012 04:32 PM
Sure sounds like the leach feild has failed, or distribution box is messed up.
Where you there when they pump the tank? Did you see water rushing in from the drain lines to the leach field as it was being pumped?
As septic tank is always full of water.
It may have worked for a while because the tank and the drain lines where emptyed so the gray water had a place to go.
TheEplumber 12-07-2012 04:34 PM
199 Attachment(s)
How often to pump varies. My tank hasn't been pumped in 5yrs- works fine
A baffle tee should be on the inlet and outlet
Daniel Holzman 12-07-2012 05:03 PM
The topic of how often a septic tank should be emptied has been discussed repeatedly on this forum over the past three years, do a search and you will find numerous threads with wildly different opinions. I studied this question when I was the engineer advising my local Board of Health on septic matters. The most authoritative studies I located indicated that a carefully managed system could go ten or more years between pumping with no issues, and a poorly managed system may require pumping every year.
The key issue is the amount of organic material flushed down the drain. In a carefully managed household, very little organic material is flushed, rather the organic material is composted. The actual organic load on the septic system is then quite small, and the bacteria that naturally live in the septic tank are generally capable of breaking down the relatively small amount of organic material that is flushed into the tank, preventing adverse buildup of sludge and scum in the tank. But you can actual measure the buildup very easily, by opening the manhole cover, and inserting a stick with a rag into the tank. The tank is typically only about four feet deep, so a five or six foot stick is generally adequate. You can then measure the sludge buildup in the bottom of the tank. When the sludge reaches about 10 percent of tank depth, it is time to pump.
wayneskid 12-08-2012 04:36 PM
Originally Posted by Daniel Holzman (Post 1068480)
The topic of how often a septic tank should be emptied has been discussed repeatedly on this forum..............The most authoritative studies I located indicated that a carefully managed system could go ten or more years between pumping with no issues, and a poorly managed system may require pumping every year.
Suggested pumping frequency is somewhat location/climate dependent; here in AK the temperatures are so low that there is little or no bacterial action to reduce the volume of solids. For a typical household, annual pumping is recommended.
Kapriel 12-08-2012 09:05 PM
Just a thought...... you had mentioned the toilet was "burping" Is it possible you have
a venting issue rather than a septic one ?
AllanJ 12-09-2012 10:13 AM
The normal, or equilibrium, water level in a septic tank is about 9 inches below the top. If the tank was just pumped, this level will usually be achieved in two weeks or less. No water exits the septic tank for the leach field before it gets to this level.
Then for each gallon of water entering, a gallon exits.
Normally it is not necessary to pump the tank unless much sludge and non-bio-degraded solid matter has accumulated, I would say to a third of the water depth (someone else said a tenth), or much grease (scum) has built up to fill the last 9 inches above the water level. In fact, pumping the tank out too often is just a waste of money unless the leach field has failed awaiting renovation and the role of the septic tank has therefore changed temporarily to holding tank.
If the septic tank is full to the brim then there is a problem downstream, in the leach field or lines leading to that, or at the septic tank outlet.
jagans 12-09-2012 01:32 PM
Patio???
Something here does not make sense.
1. How deep is the main running from the house to the Septic Tank? The reason I ask is that pouring a slab on grade should have no effect on the main waste line whatsoever.
2. If the toilet, or any fixture burps, it is not properly vented. If it backs up, either the septic system is not working, (Clogged Leach Field)or you have improper slope from the house to the septic tank, and the solid waste is settling to the bottom of the main. This can happen with too much slope, as well as not enough. The slope has to be adequate to keep the solid waste suspended in the flow of water. If you have water saver toilets, pull out the baffles. They are the worst things ever invented, IMHO.
3. Hopefully, nobody in your house throws swifter pads into your toilets. These things can clog up a septic system.
4. There used to be those that said that if a septic system is designed properly, it will never need cleaning out. Now that we flush all kinds of stuff down the toilet that is not organic, that is probably no longer true. I use Dif in mine just to jump start the bugs once in while. The Septic guys say to pump your system every two years, but then they get paid to do it. The real answer is "It Depends"
denemante 12-09-2012 09:16 PM
Based on everything here, I think the first thing I'll try is cleaning out the main. I have a washout in the patio about 15 from the inlet on the tank, so I'll try that first. Is there any basic product from the home depot I might use? I was going to try a hose. But if there is some flexible fiberglass rod with a ball on the end, maybe that would be better.
Next - yes, the basement toilet burping has been noted as a possible venting issue. It's strange that this burping happens when water is used elsewhere in the house. Also burps once when the basement toilet is used. Again, this only happens this time of year.
Worth noting is that the basement bathroom was subbed/pre-plumbed. The main house drain is 25 feet away from this bathroom coming down the wall and into the slab. So somewhere under the slab, they meet, become one, and go out under my patio to the tank.
Since it burps when other water is used in the house, common sense says there is some sort of blockage in the main after where they meet, and instead of the upstairs waste easily flowing out to the tank, somehow, it meet resistance and pushes the air in the bathroom drain back towards it, compressing the air a little, and causing that toilet to burp.
Or, it's creating suction as that waste does go out the main, and actually pulls on the air in the bathroom drain, with similar effect.
There's a studer vent on that toilet...
