Septic Bad?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-12-2012, 09:45 AM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 226
septic Bad??
I had my septic pumped 6 weeks ago, It is Feb, and we have had warm weather but, the ground above the tank is softer than the rest of the yard. I no that is not uncommon, but it never seems to freeze, just a litle crusty on the top layer of grass. But I've noticed that some snow had fallen and on my walkway where the septic pipe comes from the house, is clear of snow, melted!!
In all the winters I've never seen that.
Septic guy said my system looks good, but all he did was pump it out, can he tell just by pumping it out??
Also, could it e that my tank cover is not seated correctly, causing some extra warm air to creep up??
The tank is about 6-10 inches below the surface, ..also, I live in Massachusetts, so we been having warmer weather.
Barry
Barry J is offline   Reply With Quote
Old 02-12-2012, 10:20 AM   #2
the Musigician
DangerMouse's Avatar
Has anyone been driving over it?
DM
Old 02-12-2012, 10:23 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Sounds normal to me. A septic system generates a lot of heat, coupled with a above warmer than normal winter.
I lived in Connecticut for many years and have seen what you describe many times.
Coastal South Carolina
Old 02-12-2012, 10:32 AM   #4
DIY Homeowner
Barry J's Avatar
Rewards Points: 226
No ,,no one drives over it. I'm just paranoid about a failing septic. Hope that it's alright. I know since we've owned the house, the vent pipe on my roof, stinks when we do wash or take showers. Septic guy said buy a "charcoal filter" for the top of the pipe.
I'll do that in the spring
Old 02-12-2012, 11:19 AM   #5
Rewards Points: 12,808
That vent is suppost to stink, but not enough to notice it on the ground, it tells you the septic is breaking down the soilds.
If the vent pipe is not high enough above the roof line or it's blocked so wind can not pass over it to draw out the gas it builds up more and stinks.
Take a straw and put the end of it in a glass of water, now blow over the straw at a right angle. The water will rise up the straw. Same thing with the gas in your vent pipe.
septic emergency? help! denemante Plumbing 47 11-21-2011 02:05 PM
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 07:35 PM
septic tank problems. littles Plumbing 1 02-24-2010 10:30 PM
Foul smell from abandon septic tank in house tsduncster Plumbing 12 12-19-2009 09:55 AM
Septic Newbie Needs Advice flyboy Plumbing 5 04-06-2009 07:05 PM
