Separate Shower And Bathtub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-04-2012, 11:31 PM   #1
separate shower and bathtub drain
I am remodeling a bathroom by adding a bathtub. The bathroom has an existing shower drain. Can I hook up the bathtub drain to the shower drain? It would seem to me that with I drain the bathtub it would back up into the shower. If so, what are my options?
23675S is offline   Reply With Quote
Old 03-05-2012, 05:35 AM   #2
DIY staff
Rewards Points: 7,174
Have you exposed the plumbing under the floor yet? We need to know what exists and where to give you any guidance.
Showers need a 2" drain--tubs only 1 1/2" --your existing tub drain pipe must be 2" in order to handle the new shower.
Also let us know approximate age of house and type of piping and drains.
plummen (03-05-2012)
Old 03-05-2012, 06:25 AM   #3
mike owes me $53 dollars
Tech Dawg's Avatar
Provided the age of the home, you may also want to inspect the roof to see how many vent pipes exist. You may need to add one.
Todd
www.aloneeagle.com
Tech Dawg is offline   Reply With Quote
The Following User Says Thank You to Tech Dawg For This Useful Post:
oh'mike (03-05-2012)
Old 03-05-2012, 07:53 PM   #4
Rewards Points: 636
depends on code used in your area but 1 1/2 can be used for shower even though i will not do it
http://publicecodes.citation.com/ico...017_par002.htm
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-05-2012, 08:27 PM   #5
A 2" drain is good enough for a shower and a tub. My advice is to check if it is galvanized. If it is then tear it out while you are working on it and replace it with abs.
homefixr is offline   Reply With Quote
Old 03-06-2012, 12:21 AM   #6
My existing shower has a 2 inch drain with a vent and runs about 5 feet to the main stack. My orginal idea was to continue the 2 inch drain line to a new bathtub. I was afraid that when I drain the bathtub, it would back up into the shower pan since they are on the same drain line. I have come up with a way to make the bathtub have its own 2 inch drain line to the main stack so I should eliminate the posibility of backing up water into my shower.
Thanks for you help.
Old 03-06-2012, 07:43 AM   #7
The only way water would back up like that is if you have a galvanized drain system and the inside is all swollen and rusted, thus causing a restriction. I had that problem in my kitchen, i hit the garbage disposal and i had a fountain on the other side of the sink. Solution, replace with ABS
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 10:40 PM
Rerouting shower drain for bathtub. Jim F Plumbing 17 04-06-2010 07:25 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
convert bathtub to shower argos Plumbing 10 02-19-2008 11:53 PM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 08:59 AM
