Semi-permanent Plumbing Caps? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2015, 11:15 AM   #1
Rewards Points: 489
Semi-permanent plumbing caps?
I have a couple drains I want to cap off for the time being, but use later. This is a bathroom that I temporarily set up in the basement, but now want to disable until I get around to finishing the basement- could be a year; could be never.
The bath tub should be easy, because the fittings are below the top of the slab in a gravel pit. Once I figure out how to cap it, I can cover it with gravel. I could cut the PVC and glue on a cap, but I'd rather not. Do they make caps that fit trap fittings? Otherwise, I'll make a disc out of plastic and put it under the slip joint cap.
The bigger problem is the toilet flange. The pipe is set in concrete, so I had to use the type that fits inside 4" pipe. There's no way to remove it and cap it without cutting out all of the concrete around it. An expanding plug doesn't fit because it's an oddball size. I did a search, and found where people had taken a flange with a knock-out test plug, and bolted it on upside down over the flange. Will this pass inspection? Seems kind of hack to me. I could make a cap out of flat 1/4" or so plastic, but it needs to pass inspection, as the house hasn't had final inspections yet. I don't want to leave the toilet in place right now, as I would then have to pull a permit for the basement bathroom, and I'm not in a position to finish that project right now.
Any ideas on a code-compliant fix? I will pull a permit when I get ready to do the bathroom, but I'm not ready for that right now (time and money). What do people do who want to remove a toilet for the time being? Thanks!
MushCreek is offline   Reply With Quote
Old 04-06-2015, 02:18 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 684
My inspectors except permanent-caps glued on or gem caps held on by its stainless steel clamp. All other methods are considered temporary- even expansion plugs. Your inspectt might fee it differently.
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (04-06-2015)
Old 04-06-2015, 05:23 PM   #3
Rewards Points: 1,958
http://www.grainger.com/category/pip...ecatalog/N-n0s
Find your size and use these for toilet.
The rest should be capped with a scd 40 perm cap.
The Following User Says Thank You to Ghostmaker For This Useful Post:
rockandroller (05-08-2015)
Acrylic Solid Stain vs Oil Semi Trans or Semi solid torxx Painting 19 10-03-2012 08:37 AM
moisture under slab, roughed-in plumbing bergerdude Building & Construction 4 03-25-2011 08:29 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 11:14 AM
