Sediment In Hot Water Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2010, 12:35 PM   #1
Sediment in hot water lines
We have very little HOT water coming out of most of our sink and bathtub faucets. We believe that it is sediment from the hot water heater. We didn't know you were supposed to drain the water heater to get rid of sediment. Is there a way to flush this through the pipes or do we need to have someone replace the hot water pipes going to each faucet?
BrendaB is offline   Reply With Quote
Old 12-30-2010, 03:56 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,... Generally speakin',.. It's the water heater, or the faucets, Not the pipes...
Have you drained the crud outa the water heater,..??
What sorta faucets,..??
Old 12-30-2010, 05:57 PM   #3
Rewards Points: 150
You need to FLUSH your water heater at least once a year, that means that you put a hose on the drain down at the bottom of the
heater and run the water under pressure until it drains clear; turn the water heater off first
braindead is offline   Reply With Quote
Old 12-31-2010, 11:52 AM   #4
Rewards Points: 3,130
Do you know what kind of piping you have (galvanized, copper, plastic)? If you have galvanized, that could be the problem.
Old 12-31-2010, 12:08 PM   #5
Copper
Old 12-31-2010, 02:52 PM   #6
Then I guess you need to flush your water heater. It's not that difficult.
Old 12-31-2010, 04:05 PM   #7
Experienced
Jackofall1's Avatar
Have you tried to remove the screen filters on the end of the faucet? I bet is they plugged not the piping.
Old 01-01-2011, 02:28 PM   #8
If it was the faucets we would be having trouble with cold water, right?
Old 01-01-2011, 02:38 PM   #9
Experienced
Jackofall1's Avatar
If the faucets were common to one outlet, yes it would appear to be no pressure on both. But did you try and clean the screens? just unscrew the end and see whats there. If you have sediment in would surely be there to.
Tags
hot water heater , hot water piping , sediment
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Change out Galvanized water lines? mxingislife Plumbing 5 10-28-2010 05:39 PM
Hard Water or Water Heater Sediment ? sdcards Plumbing 6 08-20-2006 06:37 PM
