Sediment in fixtures from Plumbing
NO1B4ME (I got that, by the way) try this: go to an outside faucet that may come off the main water line before water goes to the water softener, the pre-filter, and the tankless heater. Run some water into a clean, glass, jar (clean mayonnaise jar), let it settle and see if there is sediment in it. You may even try this at an outside faucet, say on the back of the house, to see if there is any difference. One other thing, have you ever seen firemen go to a fire hydrant and open it to flush out the water lines? You may need to do this all within, and outside your home, with all the strainers off the faucets. Good Luck, David
