Sediment Filter.... - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2010, 12:28 PM   #1
Sediment Filter....
It seems that I ahve a bit of sediment coming in my lines from my well pump. I see that there are sediment filters available in Home Centers, but is there anything else that can be dome to mitigate this problem before it enters the house?
Are there filters that can be attached to the pump directly without messing with the Head, or flow?
apex_predetor is offline   Reply With Quote
Old 03-16-2010, 12:53 PM   #2
Rewards Points: 150
How old is your well?? Wells should never pump anything but clean clear water.
user69544 is offline   Reply With Quote
Old 03-16-2010, 02:33 PM   #3
Well is approx 5 years old. The house was built in 2004/2005 as was the well.
There will always be some sort of "grit" in the well water due to the extremely small size of silt and sand particles, and their inability to precipitate I would assume? Isn't that why they sell sediment filters in Home Depot and Lowes? First time on well water here.
Any other ideas that would be the cause of the sediment besides that age of the well?
thanks again for the info.
Old 03-16-2010, 02:42 PM   #4
Rewards Points: 150
Sounds like it was never right in the first place. Is it screen or bedrock well? What type and size? This will be on your well log. Or, ask the driller or county.
Old 03-16-2010, 02:50 PM   #5
Oh man. I have no idea what type of well it is? Is that something that would be detailed in teh building permit process?
thanks
Old 03-16-2010, 03:01 PM   #6
Rewards Points: 150
thanks
In my state we do need a permit to drill. Is your pump in the well?? If so, what does the well casing looks like??
Old 03-16-2010, 03:12 PM   #7
Pump is in the well I would assume. There is a steel tube sticking out of the ground in my yard. I am not sure how deep it is. I just looked at teh most recent building permit in our municipality and there is a spot to detail the well.
I have a call into the codes inspector so I can get a copy of that to continue my investigations.
Old 03-16-2010, 04:51 PM   #8
Rewards Points: 150
That well never should have never pumped sediment. You would have no recourse on the driller now.
Call a local driller and see what they say. There are ways to fix it. If it has a screen, they could slide a sand blocker screen in it. A bedrock intake well can be lined. Neither one is a hard thing to do. (for a driller)
Old 03-16-2010, 10:57 PM   #9
Doing it myself
Alan's Avatar
Rewards Points: 2,086
LOL. Not around here they don't.
Journeyman Plumber
Old 03-16-2010, 11:25 PM   #10
Rewards Points: 150
It is code in Michigan.
whirlpool refrigerator has broken filter stouron Appliances 20 09-18-2014 05:08 PM
Putting a filter in my cold air trunk? BowDown HVAC 8 09-18-2009 12:16 PM
Hog Hair Filter mjbxx HVAC 10 04-10-2009 09:46 AM
Bypass Humidifier goes before or after air filter? key1cc HVAC 9 12-30-2008 10:12 AM
Furnace/Air Filter Cover bcme136 HVAC 14 09-25-2008 07:34 PM
