Securing Utility Sink Drain Line Without Access - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2013, 05:20 PM   #1
Securing utility sink drain line without access
I am trying to add a utility sink in our garage in a house with a finished basement.
There is an area between the two floors where I can run the drain with enough slope to connect to the main drain line of the house. However, the problem is it would be about 18ft of pipe. I wouldn't have access to the area where I run the pipe, but am only pushing the pipe through to the other side, meaning I only have access to both ends of the pipe. The problem is securing the drain pipe as I don't have access to the middle area where the pipe runs.
Any ideas or suggestions? If it is a simple drain line for a utility sink should it still be secured somehow besides at the two ends?
atDev is offline   Reply With Quote
Old 07-14-2013, 05:44 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Finding access is up to you- but plastic drain pipe needs to be supported at 4ft intervals.
Old 07-14-2013, 06:57 PM   #3
Rewards Points: 1,772
You also will need a vent on that drain.
Old 07-14-2013, 07:55 PM   #4
Is there a different material as far as pipe goes that would work better for my scenario or is finding access and using pvc my only choice?
Old 07-14-2013, 08:09 PM   #5
Plumber
Rewards Points: 452
There's cast iron- it needs support at it's joints or within 18" of the joint and every piece must be supported. It comes in 10ft lengths
Then there is copper DWV pipe- it's spendy, and I believe it needs to be supported at 8ft spacing- maybe 10ft, I can't remember the code spec.
It comes in 20ft lengths
Thats about it
The Following User Says Thank You to TheEplumber For This Useful Post:
atDev (07-14-2013)
Old 07-14-2013, 08:14 PM   #6
Since this is in the garage would an air admittance valve be sufficient for venting as long as code allows it? There isn't anything over the garage so I could technically run a vent all the way up but it seems the valve would be easier.
Old 07-14-2013, 08:15 PM   #7
Thats about it
Ok thanks a lot for the answers. It looks like I am going to have to rethink how to get enough access to secure the line. I was too focused and excited that I found where I could run the drain that I forgot about securing it
Old 07-14-2013, 09:16 PM   #8
Bill Kearney
Rewards Points: 1,174
Is the garage conditioned space year round? Likely not. So, have you thought about issues with the water pipes freezing in the winter?
wkearney99 is offline   Reply With Quote
Old 07-14-2013, 10:13 PM   #9
Lord of Slums
Rewards Points: 1,974
The question is do you want to do this right or just get it so it will work. I had too run a kitchen sink drain flat for about forty feet. About every 3 years they just snake it. No vent, it works fine, oh and it was 1 1/2 not two inch.
mj12 is offline   Reply With Quote
Old 07-14-2013, 11:36 PM   #10
There is a hot/cold faucet in the garage already. Pipe is inside a wall shared with conditioned space and looks like the water gets recirculated. I'll probably add an access so I can shut off the water at that point during the winter and disconnect the lines to the sink.
As far as the trap I can probably do that inside of conditioned space? There should be room there as well.
As far as the vent goes, I think I can technically run it the same distance over to where the main drain connection is as there is another vent pipe from a sump pump there. Would that pose any issues?
Old 07-14-2013, 11:45 PM   #11
Plumber
Rewards Points: 452
Here is a hair-brained idea for you-
Lay the pipe on a board or something rigid. Secure the pipe down
Then slid it as a unit into position and secure the ends.
If the board doesn't sag- your pipe is supported.
Now you just need to make the connections at the ends....
Old 07-15-2013, 08:47 AM   #12
Bill Kearney
That vent from the sump pump is probably for radon, NOT for water drains. You should not use that.
The Following User Says Thank You to wkearney99 For This Useful Post:
atDev (07-15-2013)
Old 07-15-2013, 12:20 PM   #13
Ah, ok then yeah a studor/aav vent may be my easiest choice. Anything wrong with using one of those for a utility sink in a garage? Otherwise it will be a 30-40ft pipe up to attic/roof.
Old 07-15-2013, 12:22 PM   #14
Yeah I was trying to think outside the box on this one and this is a good idea. After dwelling on it I think I am just going to cut a big enough access for me to crawl inside the area from the garage. Once inside there is plenty of room to maneuver and then I can patch up the drywall or even put in a permanent access for future use if needed.
The Following User Says Thank You to atDev For This Useful Post:
TheEplumber (07-15-2013)
Old 07-15-2013, 12:32 PM   #15
Plumber
Rewards Points: 452
Studor will be fine- just be sure it can breath good air, don't conceal it in a stud cavity
Sink drain leaking, question bergerdude Plumbing 3 03-27-2011 01:43 PM
Utility Sink drain? redline9k Plumbing 9 01-19-2011 09:35 AM
Can two washers drain into one utility sink? mcru Plumbing 6 07-26-2010 09:23 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
utility sink, washer drain simon Plumbing 4 11-14-2007 08:30 PM
