Securing PEX - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2009, 12:15 AM   #1
Securing PEX
What's the recommended spacing for securing pex to studs? Do you think it's OK to leave long stretches (8-10') just laying between floors?
Also from a previous professional plumber job I have these inserts that hold the pex where they go through the floor. I could not find them anywhere so I just drilled a hole slightly larger and might put some spray foam around them although they will probably still touch some wood. Is that OK?
Does PEX not need water hammer arrestors since it's plastic? I didn't see any on the previous pro job.
wildbilly is offline   Reply With Quote
Old 03-29-2009, 12:49 AM   #2
Registered User
Termite's Avatar
If you have access you need to secure it about every 48". If you're fishing it through walls then there's no way to do that.
PEX touching wood is not an issue. Foaming will work just fine if you want to.
Water hammer isn't such a big deal with pipes that can flex like PEX does. You still need arrestors at fast acting valves in my opinion...Dishwasher and washing machine, but I wouldn't bother putting them anywhere else.
Securing Romex steve37887 Electrical 3 02-23-2009 09:23 AM
Securing vent hood to top of water heater? darsunt HVAC 1 07-01-2008 09:59 PM
Securing Luan to bathroom plywood floor Happy Hiker Building & Construction 7 04-10-2008 05:02 PM
Securing your Windows XP SP2 PC (updated) poppameth PC Repairs & Upgrades 2 11-19-2007 06:52 AM
Securing studs boxer1-2 Carpentry 5 05-12-2005 05:08 PM
