Securely Join ABS Or PVC Pipe To Fittings? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-23-2010, 08:56 PM   #1
Question
Securely join ABS or PVC pipe to fittings?
Hey all!
thanks for clickin' here's my question...
I got some 3" ABS pipe here and some want to join it with some fittings using a standard pipe in hub connection. I want to test it first before I weld it with the ABS cement but I can only get the pipe about half way into the hub! I'm turning and squimin' trying to get it on but now I feel like a total wimp and have to beg for help.
I tried tapping a hammer on it and lubing up the connecting surfaces with soapy water but still nothing.
Will someone help me? Thank you!
goofy is offline   Reply With Quote
Old 07-23-2010, 11:12 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Try sanding down the pipe to a rounded slightly smaller diameter.
Mike
Mike Swearingen is offline   Reply With Quote
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 12:31 PM
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 01:53 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
misfits b/ween copper supply pipe and fittings amakarevic Plumbing 8 06-10-2008 08:39 PM
iron pipe fittings farrington135 Plumbing 1 07-13-2007 08:16 PM
