Secondary Vent Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2013, 09:40 PM   #1
Secondary vent question
I just have a quick question. When a fixture is too far from the main stack and its not even possible to re-vent to tie into the main stack and you want just run a secondary vent through the roof do you need to install a whole new waste/vent stack from the basement and through the roof or do you just need just the vent part of that fixture to go through the roof and the drain installed to the main stack?
mikem201 is offline   Reply With Quote
Old 03-15-2013, 10:17 PM   #2
just run the vent up and through the roof.
Old 03-16-2013, 01:23 PM   #3
Rewards Points: 2,038
Make sure you increase the vent size when you penetrate the roof to 3 inch 12 inches below and above the roof to prevent frost closure in the northern states.
The Following User Says Thank You to Ghostmaker For This Useful Post:
DannyT (03-16-2013)
fresh air vent question gregdk HVAC 2 09-05-2012 09:22 AM
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
Another bathroom exhaust vent question psilva8 General DIY Discussions 6 01-27-2012 09:51 PM
Vent Question bigmark77 Plumbing 3 10-14-2011 09:36 AM
Return air vent question sidewayzisbest HVAC 5 05-10-2009 03:39 PM
