Second Hotwater Heater Installed In Bathroom? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2010, 08:48 AM   #1
Military Mom of 4
Snav's Avatar
Second hotwater heater installed in bathroom?
Years ago I saw some guy on a home-renovation show who had a small, second hot water heater in his bathroom.
He installed this just to heat the water quickly instead of waiting for the water to come all the way from the main tank to the bathroom - ultimately saving water.
The inline, though, wasn't the main cold-water, it was the hot-water line from the main tank. Once the main-tank hot water made it's way into the bathroom's heater the bathroom heater automatically turned off (I think) - and let the main tank hot water through.
However - I've found little information on what type of heater is used for this purpose and other such things - apparently it's not a popular trend.
Maybe I'm just using the wrong search terms?
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 02-28-2010, 09:05 AM   #2
The only reason I can imagine for the extra heater to shut-off is when it reaches the set temperature. Seems like a waste of energy to me. Water is certainly cheaper than electric costs. What I would suggest is a circulating pump so hot water is always at the fixtures. I have also seen some pumps that have an on/off switch at the fixture, and you turn the pump on when you are preparing to use it. This saves money since the pump is not running continuously.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-28-2010, 09:21 AM   #3
Military Mom of 4
Snav's Avatar
Hah - maybe that's why it's not popular, because it's more wasteful (energy wise).
Maybe what I should consider, then, is just running two traditional heaters - both being smaller, overall, than the one we have now which is a 100 gallon tank so it makes sense that having 2 (40/60 or 50/50) would be sufficient and would prevent the water-lag.
Old 02-28-2010, 10:05 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If you have access to the piping underneath and are planning on doing this yourself, it would probably be cheaper to loop the hot line back to the water heater and put a pump on it than to be heating two tanks all the time. Unless of course your tank is running out of hot water and you need more volume.
Journeyman Plumber
wiring a bathroom fan, light, heater combo on two switches zddingus Electrical 9 04-22-2010 07:48 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
just installed some bathroom fans and... listo HVAC 2 11-19-2008 12:19 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
