A Second Gas Leak Thread... New Issue... - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2008, 06:55 PM   #1
A second gas leak thread... new issue...
I had a new ( to me ) house inspected. The inspector found several
gas leaks at different places in the house, heater supply line, dryer
supply line and a 3rd leak 'somewhere'... he could not locate it, but we
smelled gas in one of the bedrooms... away from any gas appliances...
he said that they were small and I should not worry about and and could
have a plumber check it out in a few days. The house is not currently occupied.
I've been over there a few times to check on it ( this is the
first time the water and gas have been on at the location in
over a year ) and every time I go over there... I smell gas.
I finally (36 hours ) decided to shut off the gas at the gas
meter on the outside of the house....
I've never had a house with gas before so this is all new to me....
is shutting off the gas at the gas meter with the shutoff valve
a 'bad' thing? I plan on having a plumber check the system in a
few weeks and will just leave the gas turned off till then... is
that 'ok' or do I need to call the gas company and have them
do something other than shut off the valve like I did?
Thanks - jack
MrLinux is offline   Reply With Quote
Old 01-25-2008, 08:29 PM   #2
Master Plumber
Rewards Points: 150
You did exactly the right thing, and don't turn it on again until you have a plumber check it out. No need to call the gas company unless the problem is on their side. The plumber will probably do a pressure test on whole system and have to do a leak search, but he can start with the places that were pointed out in the inspection, fix them one at a time and pressure test until no more leaks are found.
jpplumber is offline   Reply With Quote
Old 01-25-2008, 08:57 PM   #3
Thanks. I feel better now. The needles on the gas meter have not
moved in the 3 hours since I turned it off. I'm sure that the leaks
are on the house side of the meter.
I didn't turn off any pilot lights... I just turned off the gas at the
meter. I'll tell the plumber what I did I assume that he can handle
it from there.
jack
Old 01-26-2008, 09:12 AM   #4
i would never recomend that inspector!!!
you never leave a gas leak. just not smart and to advise you to leave the gas on. just stupid!
ranman469 is offline   Reply With Quote
Old 01-27-2008, 12:02 AM   #5
remodeling pro
Lucky you had more sense than your inspector. You did the right thing to shut the gas off and bring in a licensed plumber to find the problem.
I guess a "small" gas leak will only cause a "small' explosion, thus you will only be maimed and not killed? I would have serious questions in my mind about anything else this moron has , or more importantly doesn't have, in his report.
troubleseeker is offline   Reply With Quote
Old 06-15-2009, 07:45 AM   #6
BoliBaite's Avatar
buy drugs
acheter Celexahttp://houseoftutors.edu/index.html
BoliBaite is offline   Reply With Quote
Gas Leak!! mlconti Plumbing 4 01-25-2008 06:53 PM
Basement leak dougrus Building & Construction 7 12-31-2007 07:06 PM
pipe leak & sheetrock damage santogr General DIY Discussions 2 03-04-2007 01:44 PM
Hot water heater leak? chrisintroy Plumbing 3 02-27-2006 09:13 AM
