Old 12-06-2009, 07:02 PM   #1
Sears Kenmore Ultrasoft 425 Water Softener
Problems with auto control of regeneration. I've been through all the troubleshooting tips, cleaning and flushing of all items. This system is, and always has been clean and trouble free.
I have to put it into manual regeneration every time because it will not do it on it's own. Even when the display indicates it is going to 'recharge tonight', it never does. It seems that everything else works and senses ok. The unit counts usage fine, and all settings are ok for setup of hardness, etc. It goes into regeneration fine when I press and hold the button. It operates ok and goes through all the cycles and produces soft water.
I'm lookiing to find out why the auto function doesn't work. Only thing left in my mind is the circuit board, but cheapest I can find one is $161 plus shipping. Don't want to buy it if I'm not 100% certain that is the problem. If anyone can shed light or provide some insight to this issue I would appreciate it very much. Very frustrated at this point.
Thanks,
greyman is offline   Reply With Quote
Old 12-06-2009, 07:50 PM   #2
An old Tradesmen
Moved to plumbing.
Although its an appliance. You'll probably get better results here.
Old 12-06-2009, 08:28 PM   #3
Discount parts for Kenmore water softener? unknownsoldierx Plumbing 7 03-05-2012 08:25 PM
Soft water softener leaking salt taste into plumbing??? BobnSofi Plumbing 2 06-01-2009 12:27 PM
Help with Water Softener TTran Plumbing 5 05-27-2009 07:08 PM
Kenmore Refrigerator - Water Dispenser bradels Appliances 1 04-04-2009 09:37 AM
Water Softener "LOWERS PRESSURE" HELP! BobnSofi Plumbing 3 03-23-2009 03:24 PM
