Sealing A Water Line To The Back Of Fridge. - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-11-2013, 03:18 PM   #1
Rewards Points: 34
Sealing a water line to the back of fridge.
I am pretty inexperienced in this kind of stuff, and the guys who installed the fridge never installed the water line. What do I use to seal this? I screwed it on tight and turned on the water and it didn't hold a seal obviously... Thanks for the help!
http://s11.postimg.org/cf353n78j/SAM_3869.jpg
Sojumonkey is offline   Reply With Quote
Old 09-11-2013, 03:43 PM   #2
DIY staff
Rewards Points: 7,174
You can not use the brass ferrule on plastic tubing---you need a tubing liner(looks like a hollow brass rivet and slips inside the tube) and a nylon ferrule---
Any hardware store will have those two items.
Old 09-11-2013, 04:29 PM   #3
Cut the end of the hose off (including the ferrule). Slide on a new ferrule and tighten it to the fitting. It looks look the last time it was tightened that the hose was not held straight... see how the ferrule is cockeyed?
Go gentle on the tightening ... Only enough to keep it from leaking.
RoyalAcresRod is offline   Reply With Quote
Old 09-11-2013, 04:34 PM   #4
You're right Mike. Thant you ...my bad
Old 09-11-2013, 06:28 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 676
If it was my project- I'd dispose of the plastic line and use a 1/4" braided ice maker line.
I just did a service call on one of those plastic lines last week. The kitchen now has pretty, new flooring due to water damage and a nice flex line. Just saying.....
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (09-11-2013)
Old 09-11-2013, 09:10 PM   #6
when using plastic tubing you need the little brass tube that inserts into the end of the plastic so the ferrule doesn't crush it. most of the brass fittings i see now come with the little brass tube.
Old 09-12-2013, 12:06 AM   #7
Looks like the stiffener is missing on the inside of the tube in that pic.
VIPlumber is offline   Reply With Quote
Old 10-06-2013, 12:42 PM   #8
Rewards Points: 34
thanks guys. finally going to be able to get this done this weekend.
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Leak with water line from pipe to fridge rygar Plumbing 16 05-22-2013 07:21 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 12:05 AM
Need Assistance - Broke valve where water line feeds to Fridge... BDPNA Plumbing 7 08-10-2009 08:38 PM
