Sealing Threads On Water Feed In Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2008, 10:38 AM   #1
Sealing Threads on water feed in shower
I have a decorative water feed for my shower hose. It needs to be mounted against ceramic tile, so I can't crank down tight on it. The brass nipple that goes through the wall threads into a female elbow in the wall. I have have used teflon tape and threaded the nipple into the decorative fitting and now need to thread it into the elbow inside the wall. I have the best length nipple that isn't too long.
This means when I thread it into the elbow, it does not tighten all the way into the elbow. I can't keep tightening it or I will crack the tile. I have plenty of thread into the elbow, I just can't bottom out the nipple all the way into the elbow. What should I use to assure the nipple/elbow threaded joint does NOT leak in the wall?
Teflon tape or joint dope? or both?? Thanks for your help
MickeyC is offline   Reply With Quote
Old 01-17-2008, 12:32 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,602
A Longer Nipple.......
No amont of Pipe Dope or Pipe Tape will seal a fitting left Loose......
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water dripping in the shower??? Sellncars Plumbing 4 12-05-2009 08:07 PM
Are shower water problems caused by old pipes? bathroom nightmare Plumbing 17 02-02-2008 10:39 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
