-   -   Sealing Threads on water feed in shower (http://www.diychatroom.com/f7/sealing-threads-water-feed-shower-15728/)
MickeyC 01-17-2008 10:38 AM
I have a decorative water feed for my shower hose. It needs to be mounted against ceramic tile, so I can't crank down tight on it. The brass nipple that goes through the wall threads into a female elbow in the wall. I have have used teflon tape and threaded the nipple into the decorative fitting and now need to thread it into the elbow inside the wall. I have the best length nipple that isn't too long.
This means when I thread it into the elbow, it does not tighten all the way into the elbow. I can't keep tightening it or I will crack the tile. I have plenty of thread into the elbow, I just can't bottom out the nipple all the way into the elbow. What should I use to assure the nipple/elbow threaded joint does NOT leak in the wall?
Teflon tape or joint dope? or both?? Thanks for your help
Bondo 01-17-2008 12:32 PM
A Longer Nipple.......
No amont of Pipe Dope or Pipe Tape will seal a fitting left Loose......
