Old 03-19-2009, 02:11 AM   #1
sealing threads
Hi,
I'm installing a new tub set, pressure balance valve and separate transfer valve. One has male IPS and the other female IPS. It all seems good but I'm feeling that last sense of paranoia before I close up the walls and start tiling. I've had my share of threaded hose bibs that start leaking even though I used teflon tape and made them good and tight. Unline sweat joints which I feel confident will last forever if they last for 5 seconds, threaded joints always make me nervous.
I'm wondering now whether something like putty would be a better, safer more permanent sealant for threaded joints rather than tape?
Eric
everyman is offline   Reply With Quote
Old 03-19-2009, 03:59 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
sealing threads
Use pipe compound or teflon tape, not putty.
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-19-2009, 09:10 AM   #3
HVAC / Plumbing
sealing threads
Mike
Agreed,,,,, I don't use tape at all never had much luck with it
kenmac is offline   Reply With Quote
Old 03-19-2009, 11:05 AM   #4
sealing threads
You could use a pipe joint compound (not putty) for these joints. I like Rectorseal and always use it for gas services. People think that thread products are for "sealing" the joint. Pipe threads are tapered. If you lay a pipe nipple on a flat surface, you can see the taper. Thread "sealants" are actually thread "lubricants". They assist in getting the joint tight.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 07:36 PM
Sealing Threads on water feed in shower MickeyC Plumbing 1 01-17-2008 01:32 PM
Damaged pipe threads Steve J. Plumbing 5 12-03-2007 12:33 AM
loose pipe threads fixitmom Plumbing 2 10-25-2007 11:56 AM
Rigid Metal Straight Threads rjordan392 Electrical 2 06-24-2007 12:42 PM
