Sealing Main Stack - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-25-2010, 02:11 PM   #1
Sealing Main Stack
I am experiencing leakage on the floor surrounding the main stack in my home. I am wondering if it is possible to seal the leak from inside the stack with epoxy, etc.
tjytiedt is offline   Reply With Quote
Old 10-25-2010, 03:05 PM   #2
fabrk8r
fabrk8r's Avatar
Can you provide more information?
Is it a plumbing vent stack or furnace vent?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 10-25-2010, 03:21 PM   #3
Sealing Main Stack
It it the plumbing stack (black PVC).
Old 10-25-2010, 05:38 PM   #4
fabrk8r
fabrk8r's Avatar
The best way to repair it is to cut out the leaking joint and replace it with new ABS pipe (PVC is white). It's a fairly simple repair if you have access to the vent stack. You probably should open the wall up anyway to check the extent of the water damage.
Max run for 3" Toilet run to main stack brokenhammer Plumbing 2 01-27-2010 06:52 AM
Basement toilet: Watergenie - how to connect to main stack GD73 Plumbing 1 12-21-2009 10:13 AM
Main stack issue Elka Plumbing 3 10-14-2009 10:17 PM
Type of pipe for main stack to septic tank GD73 Plumbing 2 08-28-2009 10:17 PM
Tie into main kitchen stack gdub1973 Plumbing 1 08-02-2008 04:23 PM
