Sealing A Leak, No Hub To 3" Cast - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-10-2012, 01:51 PM   #1
Rewards Points: 562
sealing a leak, no hub to 3" cast
Is there something to 'wrap' the cast pipe I snapped clean at floor level to help the clamp seal better? or use another clamp? Almost seems the pipe is a bit smaller than the no hub sleeve. Tightening further may strip the threads on the clamp.
Its a small seep on a bare concrete floor,,,,but nicer if it stays dry. Think I can loosen the clamps and slide it up if needed to fix. Cant slide pipe sideways because of the tree type connections.
4just1don is offline   Reply With Quote
Old 04-10-2012, 08:38 PM   #2
Rewards Points: 582
if the pipe is rusted alittle you could grind it some or what we do is heat up the fernco to soften the rubber then tighten it up>>>>just a thougth>>>>>
Old 04-10-2012, 08:50 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 564
If you are joining CI to plastic, you need the correct transition no-hub coupling. CI is slightly smaller O.D. then plastic. The transition band will compensate for this. A normal NH coupling will pucker a little bit and not seal on the cast.
The Following User Says Thank You to TheEplumber For This Useful Post:
jaydevries (04-10-2012)
Old 04-10-2012, 11:21 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
I use pvc cement inside the rubber before installing no-hub couplings sometimes on older pipe to prevent that
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 04-11-2012, 03:05 AM   #5
Rewards Points: 562
it is NOT rusted therefore that tip wont work;
E Plumber, I am stuck with this sleeve and clamps since I cant get this one off nor a new one on. In all the years of looking in those parts bins have never seen one of those you speak of,,,course we live in middle of midwest and dont have many such thungs. Stores only stock what they sell alot of hence the universal straight rubber sleeves with hose clamp on both ends. Label says it will work,,,it doesnt perfectly.
Will pvc glue hurt the rubber any??? Think I will try 2 more hose clamps first,and if that doesnt do it I surely will try glueing it as you suggest. Wish I could get a wrap or two of bicycle innertube around it and slip it down over without rolling it,,,have used that before with great success in other apps. Much like teflon tape on steroids.
How should i repair this cast iron drain leak? markcal02 Plumbing 14 10-20-2011 05:03 PM
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 04:41 PM
Cast iron baseboard leak Lisac Plumbing 3 04-10-2011 03:22 PM
Cast iron sink drain leak Hyrumbradshaw Plumbing 1 03-13-2011 08:52 PM
Leak in Cast Iron? Pipe under toilet... terrapin88 Plumbing 11 11-19-2009 05:54 PM
