Sealing Escucheon Plate/flange... - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2011, 09:10 PM   #1
simeltzer's Avatar
Rewards Points: 46
Sealing escucheon plate/flange...
Just finished a new shower enclosure and installed a price pfister shower head and single knob valve. The back of the flange comes in the box with a sort of weatherstripping (foam) material which is supposed to compress and seal out water. I feel skeptical about the effectiveness of the foam and wonder if i need to use putty in addition to or instead of the foam. My buddy who is a gc said the foam is newer thing and will work just fine. Am i being paranoid? What should i do?
Sealing escucheon plate/flange...-038877532577xl.jpg
simeltzer is offline   Reply With Quote
Old 01-31-2011, 09:36 PM   #2
It is certainly not going to hurt anything to put some type of sealant around the trim plate. I usually do not add anything to the foam, but sometimes if the hole in the wall is big, I will use some caulk.
broox is offline   Reply With Quote
Old 01-31-2011, 11:02 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 564
Foam has been a part of shower trim for awhile now. I always add a bead of clear caulk/silicone around any shower/tub trim that could get water on it
Old 02-02-2011, 03:54 PM   #4
simeltzer's Avatar
Rewards Points: 46
Thanks for the input guys, i think i will let it be for a while and check on it in the 'not too distant future.' i am pretty sure that the foam is compressed well.
sealing compound?! mmhendrie Electrical 1 07-18-2010 06:51 PM
Sealing new boxes on an exterior wall Mthrboard Electrical 1 08-16-2009 08:05 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
Grout lightened after sealing SueT Tiling, ceramics, marble 6 11-23-2008 08:58 PM
sealing up air leaks between troyce1 General DIY Discussions 2 10-15-2008 08:14 AM
