Old 10-20-2012, 01:54 PM   #1
Sealing crack in plastic utility sink
Hi,
I have a plastic utility sink with a 6 inch long cut or crack in the basin (not at the drain). If I have anything with some weight to it in the sink it will cause water to leak through the crack when running the water.
Is there any way I can seal this crack, perhaps some type of caulking or sealant along the crack both inside the sink and underneath?
plg_cp is offline   Reply With Quote
Old 10-20-2012, 02:03 PM   #2
I noodled on this, and it would seem your biggest issue will be keeping any kind of seal when the weight of the water flexes the sink.
I'd be tempted to try a repair using 100% silicone caulk - it comes in white, clear and black (and maybe a few other colors). Be sure you thoroughly prepare the surfaces, and I'd recommend using a dremel wire brush bit to rough up the seam edges both top and bottom. Wipe them with rubbing alcohol just prior to applying the silicone so you can be sure no soap residue remains to affect the bond.
Then apply a nice thick bead to the bottom, and a decent but not grossly oversize bead inside the sink. Let it dry per instructions on the tube.
Be sure it is 100% silicone, and you might have a chance. Silicone will flex without tearing, and in my experience will bond to darn near anything. If you can fabricate a brace for the bottom of the sink to prevent flex it would really help, regardless of what you use to seal it.
imautoparts is offline   Reply With Quote
The Following User Says Thank You to imautoparts For This Useful Post:
plg_cp (10-21-2012)
Old 10-20-2012, 02:10 PM   #3
JB WELD seems like a good choice for this project.
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
plg_cp (10-21-2012)
Old 10-20-2012, 03:12 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
As cheap as those tubs are, you would be better to just replace it alltogether.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
The Following User Says Thank You to gregzoll For This Useful Post:
oh'mike (10-21-2012)
Old 10-20-2012, 04:04 PM   #5
Drill a hole at both ends of the crack,then use epoxy on both sides to seal the crack,the holes are to keep the crack from going any further.
Canarywood1 is offline   Reply With Quote
Old 10-20-2012, 09:33 PM   #6
replacing it is the only real way to fix it.....ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 10-21-2012, 01:11 PM   #7
Thank you for the suggestions. I will compare silicone caulk and JB Weld and try one of them. If that fails then I'll replace the sink.
Utility Sink with pictures! Bloke Plumbing 20 05-13-2011 01:16 PM
How to add Utility Sink and Washer Drain to existing 4" obriendigital Plumbing 9 03-26-2011 07:39 PM
Bar Sink and Utility Sink Drain Line - T or Wye mykayel Plumbing 7 01-12-2011 10:34 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 02:21 PM
Question about installing plastic sink basket gone_fishing Plumbing 7 06-20-2010 01:24 PM
