Sealing 3" Rodding Access Threaded Connections - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2009, 04:44 AM   #1
Sealing 3" Rodding access Threaded connections
Hi, just trying to find out what method you use to seal 3" rodding access threaded connections (with square end) within a drain set up, not sure if PTFE tape is ok or not......
Ones I have looked at seam to be a threading compound, I was just concerned that if a compound was the correct method would this be really hard to undo?
Many thanks!
Invisible-Man is offline   Reply With Quote
Old 09-24-2009, 09:26 AM   #2
BIGRED
Rewards Points: 252
I SEE YOU! PTFE tape or any plumber's pipe dope is adequate just so long as it is non-hardening.
Grampa Bud is offline   Reply With Quote
Old 09-24-2009, 11:16 AM   #3
LOL............Thanks for the info!!!
Old 09-28-2009, 09:11 PM   #4
i just used a ptfe pipe dope. works just fine
fhrace is offline   Reply With Quote
Old 09-29-2009, 04:53 AM   #5
Thanks!
