Screwing Down Toilet Pipe Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2012, 05:41 PM   #1
Newbie with a hammer
screwing down toilet pipe flange
I am mid-renovation of a bathroom, yesterday pulled out the toilet and the tile floor. The subfloor layers - both the plywood and whatever it is underneath - were not cut very clean by the previous installer, so the toilet flange does not screw down very well. It also looks like there had been some minor water damage at some point, though not enough that the floor is rotten. I'm trying to avoid replacing the subfloor, and am wondering if there is anything that I can put in there to fill the gaps and also grab the screws on the toilet flange. Ideally some kind of wood filler, but I'm not sure if that's a feasible option. Also was thinking of larger diameter screws, but I don't know if that would work either. Again, I don't really want to pull out the floor if there's an alternative, as I don't think the wood is bad. Any suggestions?
trekkaround is offline   Reply With Quote
Old 12-17-2012, 05:55 PM   #2
Rewards Points: 636
maybe this will work
http://www.siouxchief.com/Specialtie...-Support.DBONO
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
TheEplumber (12-17-2012)
Old 12-17-2012, 06:00 PM   #3
Rewards Points: 14,312
Got a picture?
Now would be the time if that floor, needs to be replaced, not later after your done reflooring.
There no "filler" that's going to do any good.
If your going to chance it anyway then just drill some new holes and counter sink them.
Old 12-17-2012, 08:43 PM   #4
Roofmaster
Rewards Points: 2,210
The flange is supposed to be fully supported, and sit on top of the finished floor. If you are in the midst of a renovation, why would you do it half assed?
Send some pictures and we will tell you the right way to do it. If you dont want to do it right, whats the point? Hire somebody else to screw it up so you can blame them, not yourself.
Old 12-17-2012, 09:07 PM   #5
SuperJETT's Avatar
Rewards Points: 156
I used that repair kit in our house and it worked well, but you have to be able to screw it down securely for it to work properly.
SuperJETT is offline   Reply With Quote
Old 12-18-2012, 11:29 AM   #6
Special User
Rewards Points: 1,230
I've seen YouTube videos of people filling toilet flange floor "cavities" with Plaster of Paris to make a firm base for the flange to rest on. Seems effective, but I dunno if that's good practice -- seems like replacing the flange at a later date would require busting all that plaster back out of there... a bit of a pain.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
How high above sub-floor should pipe for toilet flange be left when tiling? SciGuy Plumbing 1 10-22-2012 03:17 PM
TOILET FLANGE: right position? almazon Plumbing 8 02-24-2012 10:37 PM
toilet flange question donkeyk Plumbing 15 02-01-2012 06:46 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Broken toilet flange - concrete floor rob1 Plumbing 5 09-20-2009 10:45 AM
