Screw Size For Bathtub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2014, 07:05 PM   #1
Rewards Points: 900
Screw size for bathtub drain
Hi;
I need to buy a new brass screw for the bathtub (don't know what brand, but it's in the USA, and is probably 50 years old) drain. This is the long screw that holds the drain screen in place.
I have been using whatever I have around, but the screws keep corroding on me, so I want to get a brass one, as I believe the drain itself is brass.
I tried to thread a 10-32 nut onto the screw but it did not go, so I figure it's 10-24.
Can anyone confirm this for me?
FW
Ultrarunner2017 is offline   Reply With Quote
Old 03-25-2014, 08:06 PM   #2
Rewards Points: 344
Can you post a pic of the drain screen. Thanks.
Is it something like this?
Stay tuned, I can't confirm the size of the screw, but I'm sure someone here can. I would get a couple different sizes from the hardware store and do a little trial and error. Just a thought.
jmon is online now   Reply With Quote
Old 03-25-2014, 09:29 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 996
Find a local marine supply they'll usually have an assortments of brass and stainless steel screws and bolts used on boats, as far as size different manufactures different screws and sizes.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
jmon (03-25-2014)
Old 03-26-2014, 10:03 AM   #4
Rewards Points: 900
Yes, that looks a lot like it, although my strainer is aftermarket, and really cheap. I have to replace it about once a year.
Old 03-26-2014, 06:56 PM   #5
Rewards Points: 2,106
Or a real hard ware store.. The old ones home depot and lowes killed.
Rusted and almost gone drain pan, Package unit Nordyne kilosos2 HVAC 3 11-18-2012 09:24 AM
Leaking Shower Drain - Screw Gasket eclipsis Plumbing 35 01-05-2012 03:55 PM
Old Clawfoot Tub Drain missing nut - can't find size! wombosi Plumbing 0 01-26-2009 04:48 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
reducing pipe size for sink drain bluebee1314 Plumbing 5 12-02-2007 12:53 PM
