Screw Hole On Shower Valve Broke Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-15-2012, 01:22 AM   #1
Screw hole on shower valve broke off
I was installing the handle and plate for my new shower control and the screw went in a little crooked and broke off the tab that the screw hole is on. The valve is still in place behind the wall, I just have only one screw hole now instead for two for my shower trim. What can I do to fix this without replacing the valve? I don't have the option of opening the wall behind to replace the valve because there is another brand new tiled shower on the back side. Please help!
Amymestas is offline   Reply With Quote
Old 07-15-2012, 02:01 AM   #2
Rewards Points: 616
post a pic please
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 07-15-2012, 07:16 AM   #3
Rewards Points: 1,214
Un screw the single screw remove the cover and look at it.
Is there any meat left to get a hold of?
If there is get a pair of pliers or vice grips and try to turn it out.
If not buy a real small set of easy outs and try them to get it out.
Relax take your time, the problem you might have here is the threads are stripped in the main valve you might have to run a tap through them and switch to 1 larger screw.
COLDIRON is offline   Reply With Quote
Old 07-15-2012, 11:52 PM   #4
Hi guys, thanks for the quick replies. I was able to get a pic of the shower valve. Notice the hole on the upper left in photo, there should be a screw hole on the lower right as well. When I was attaching the trim plate, the screw appears to have started going in a little bit crooked, so that leverage caused the little ear to break off. I was using a drill, but going slow and I wasn't applying excessive pressure or anything and I wasn't getting the feeling like the screw was having trouble going in. I had it almost all the way tightened and then there was just a "pop". I backed both screws out to remove the trim to see what the noise was from. Thats when I found the ear broken off.
This can't be the first time something like this has happened. I'm hoping there is an easier fix than trying to replace the valve. I just finished my tile job and can't bear the thought of having to rip anything out!
Any tips?
Old 07-16-2012, 07:08 AM   #5
DIY staff
Rewards Points: 7,174
I suggest gluing a wood or plastic strip to the backside of the backer board and then use a stainless steel wood screw.
bob22 (07-16-2012)
Old 07-16-2012, 11:24 AM   #6
Thanks for the suggestion. I will give that a try and see if I can get it to work!
Shower valve for rainshower head Liv Plumbing 0 03-29-2012 11:41 AM
Delta scald guard shower valve leak pdamania Plumbing 1 03-08-2011 06:45 PM
Shower mixing valve replacement w/galvanized pipe rsaritzky Plumbing 3 05-13-2009 11:11 AM
Shower Valve Destroyer ? Help! doneitnow Plumbing 2 05-05-2008 11:15 PM
Can't reinstall shower valve properly ptoneil Plumbing 3 04-10-2008 11:05 PM
