Screen In A Induced Draft WH Vent? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2013, 11:22 PM   #1
Rewards Points: 948
Screen in a induced draft WH vent?
I just had a 3" vent put in for an induced draft water heater. The installation instructions call for a screen across the opening. I mentioned that to the plumber; he said he would come back and put one in if I wanted it, but his experience is that screens cause more problems than they solve.
Any opinions on this?
Don't know if it's relevant, but my the instructions for my furnace don't call for a screen on it.
Toller is offline   Reply With Quote
Old 03-26-2013, 11:40 PM   #2
Rewards Points: 144
The outside screen on opening is probably for some kind of rodent, bird nest,etc. control. If your furnace doesn't have one, your hwh will probably be fine.
If u feel u need it, by all means have him install it. It is possible the screen could get clog with leaves, other debris, etc. Just make sure u check it/clean it every once in awhile.
jmon is offline   Reply With Quote
Old 03-26-2013, 11:57 PM   #3
Always learning...
fetzer85's Avatar
Rewards Points: 262
I wondered that too when we got our 95% furnace, but like you said if the furnace doesn't need one then you're probably ok.
fetzer85 is offline   Reply With Quote
Old 03-27-2013, 07:13 AM   #4
Rewards Points: 1,418
The screen, depending on the hole spacing and the kind of material used, offers some impedance to the air flow. This can be compensated for by having the pipe or duct flare to a larger diameter where the screen is installed.
Old 03-27-2013, 07:36 AM   #5
Rewards Points: 6
Where do you live? If you are in a cold area, the condensation from the exhaust can build up on the screen and clog the exhaust.
djlandkpl is offline   Reply With Quote
Old 03-27-2013, 09:04 PM   #6
Rewards Points: 1,700
Chicken wire works will. Unless you prefer a bird nesting in that pipe and croaking and in the meantime your fine family is getting carbon monoxide in the house. Because the dead bird is blocking the exit it is suppose to be using... We could always see if you wake up one morning or not,,,, I think a little screening is a great IDEA....
Frozen Vent Pipe Ratchye Plumbing 55 01-17-2017 06:21 PM
Draft Inducer Blower Not Blowing- LED Blinking 3 Times rust101 HVAC 10 04-09-2013 09:44 PM
Down Draft on Exhaust Vent causing incomplete ignition??? tigerfan HVAC 1 12-28-2010 10:51 PM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 11:40 PM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 01:01 AM
