Schedule 80 Vs 40 CPVC - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-09-2012, 04:42 PM   #1
Rewards Points: 16
Schedule 80 vs 40 CPVC
Is the 80 overkill? for replumb?
digitalplumber is offline   Reply With Quote
Old 10-09-2012, 04:54 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Schedule 80 is much more expensive than 40 and you will never win a bid quoting sch 80. You will probably lose to another plumber quoting PEX.
Coastal South Carolina
Old 10-09-2012, 04:56 PM   #3
Rewards Points: 16
Re-plumbing my sons home.
Old 10-09-2012, 05:01 PM   #4
A "Handy Husband"
rjniles's Avatar
Then just overkill. The only advantage to schedule 80 is the increased max pressure rating (which you will never see in residential applications). You will also reduce the flow rate unless you increase the size.
Old 10-09-2012, 05:10 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 352
Are you talking water pipe or drainage?
Must be water-- they don't make DWV for sch 80 that I know of--I think I just answered my own question
Pvc is not allowed inside a house for potable water....
Old 10-09-2012, 05:29 PM   #6
Rewards Points: 16
Water
Old 10-09-2012, 05:32 PM   #7
A "Handy Husband"
rjniles's Avatar
The poster was asking about CPVC.
Old 10-09-2012, 05:35 PM   #8
Plumber
Rewards Points: 352
Water
Go pex. Next to copper it's the best product- I know, some don't like copper either.
pex is DIY friendly and quite durable
The Following User Says Thank You to TheEplumber For This Useful Post:
rjniles (10-09-2012)
Old 10-09-2012, 05:39 PM   #9
Plumber
Rewards Points: 352
Ah, so he was
I wouldn't recommend cpvc at all. We used it around here for a very short time. Now it's hard to find here...
Old 10-09-2012, 05:42 PM   #10
Rewards Points: 16
Dont want to start another Pex vs the world debate, but......I have two things that stick in my head about Pex: Taste in water and flow reduction, so I have read.
Convince me...................
Old 10-09-2012, 05:59 PM   #11
Plumber
Rewards Points: 352
Never heard about water taste..
And yes, you can have flow reduction as you can with any pipe you use. Just have to know how to size the line properly.
The joining system and type of fittings also play a factor in flow characteristics.
I like to use the ProPex expander system but the tool is spendy for one project. ProPex/Uponor uses full size fittings.
The crimp system uses smaller ID fittings that will affect the flow if not considered in the line sizing but still is quite popular. You can rent crimpers too.
Old 10-09-2012, 06:18 PM   #12
A "Handy Husband"
rjniles's Avatar
+1 with what he ^^^ said.
I re-plumbed my house 5 years ago with PEX (crimp rings). I used 3/4" trunk lines to mini-manifolds and 1/2" to each fixture. I installed a shutoff to each fixture after the mini-manifold. No issues with flow or pressure.
No taste issues and why would there be any difference than CPVC.
I am surprised that you as a plumber are not already using PEX in some applications.
Old 10-09-2012, 06:22 PM   #13
Rewards Points: 16
not a plumber, digitalplumber is just a handle for this website!
Old 10-09-2012, 06:50 PM   #14
Civil Engineer
Rewards Points: 4,522
PVC pipe rating is 289 psi for 3/4 inch pipe schedule 40, 509 psi for schedule 80. CPVC rating is 480 psi for Schedule 40, 690 psi for schedule 80. 1/2 inch pipe is considerably higher. CPVC and PVC both derate with temperature. At the maximum operating temperature for CPVC of 200 degrees F, the allowable pressure derates to 20 percent of the rated pressure quoted, which is for 73 degrees F.
You are not going to run your domestic hot water at 200 degrees, typically hot water is at about 120 degrees F, at which temperature CPVC derates to 70 percent, and PVC derates to 40 percent. Even at 40 percent capacity for PVC, in theory you would have an allowable pressure of approximately 120 psi for 3/4 inch PVC at 120 degrees F, however PVC is not recommended for hot water applications. In any case, there is no reason to use schedule 80 CPVC, it is overkill and more expensive, but if you already have it, you can certainly use it.
By the way, I concur with the recommendation to use PEX, but I realize this is controversial on this forum and elsewhere.
Old 10-09-2012, 06:54 PM   #15
Rewards Points: 16
No have not bought, in the demo stage.
digitalplumber is just a name for use here, I am not a plumber!
Schedule 40 PVC question OKDrew63 Electrical 9 08-20-2012 06:30 PM
Small Schedule PVC Pipe & Fittings Zekester Plumbing 2 07-26-2012 11:39 PM
Water Heater Connections (CPVC) Pittsville Plumbing 16 01-21-2012 09:02 AM
CPVC Installation Questions Pittsville Plumbing 24 01-30-2011 09:38 PM
CPVC tubing and angle stop valve Wiscbldr Building & Construction 1 01-14-2011 11:11 AM
