-   -   On a scale of 1 -10 how hard is it to change a sump pump? (http://www.diychatroom.com/f7/scale-1-10-how-hard-change-sump-pump-38702/)
abefroman 02-19-2009 02:03 PM
Anything I should know?
On the one I have now, it looks like the sumppump is designed to work with the watchdog battery system and monitor, and it has a special cord, or special plug on the cord that plugs into the watchdog, do all/most sumppumps have that or should I look for a special model?
Thanks in advance!
:thumbup:
Bob Mariani 02-19-2009 02:20 PM
not all have them but should. for a DIY project it is a scale of 1. (easy)
abefroman 02-19-2009 02:25 PM
Thanks!
Actually, the pump with that cord looks like its the backup pump and probalby came with the watchdog.
The watch dog is giving a battery error now too, and when I tried cleaning the connectors, on of the leads broke off.
Is there anyway to replace that? It is connected right to the electronic display box. Can I just strip the end of the wire and connect it like that?
Is the watchdog+backup sumppump typically independant of the main sumppump?
Thanks again for the help.
Scuba_Dave 02-19-2009 02:26 PM
This can depend upon the existing plumbing too
Mine has a check valve in line
So it was really easy to remove the old pump & install a new one
abefroman 02-19-2009 02:29 PM
Thanks, I have the check value too.
Bob Mariani 02-19-2009 03:26 PM
if one does not have a check valve then it will just fill up again with the water in the discharge and fill again. Just cut PVC below check valve and connect new pump with a fernco coupling. The two pumps should work in tandem. If one fails the other will be used. The connections can be made directly as you suggested.
abefroman 02-19-2009 03:41 PM
Thats a good idea, the one I have looks like its suppose to unscrew though, I couldn't turn, but will try with a bigger pair of channel locks. If not I will cut a couple inches below it and use the coupling.
abefroman 02-19-2009 04:06 PM
Well, I stripped that wire, and I am still getting a red light for the battery, although if I unplug the watch dog, the battery still is able to turn on the backup pump.
I wiped the terminals off with a rag, is there I solvent I can use that would work better?
The water light wasn't on, but I topped it off anyway.
Is this likely a problem with the battery, relay in the watchdog electronic box, or terminal?
TIA
Scuba_Dave 02-19-2009 05:01 PM
Battery error might be low charge/old - need to be replaced
abefroman 02-19-2009 05:04 PM
Sheet! The battery is almost as much as a whole new watchdog.
JonC 02-25-2009 10:15 PM
Take the part number or the Volts/Ah rating from the battery as well as it's size height/width/dept and call a local battery shop like Interstate. If it's a Pb or Pb Gel type (lead acid) battery you can usually get it at a much better price than ordering a replacement from the manufacturer of the electronic device.
Also the terminal you broke off, you can usually get a crimp tool with a bunch a variety of connector ends from an automotive store. Many mid-size battery terminals are flat spade or bolt/stud type connectors which you'll find in that assortment. It's best to not twist wires directly to a battery terminal as the connection is more likely to corrode over time and lead to thermal issues under load (smoke, melting, fire, etc)
Wethead 02-26-2009 10:20 PM
I would say on a scale of one to ten, about a 4
