Scalding Hot In Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2011, 06:57 AM   #1
Scalding Hot in Shower
Hi
I went to take a shower this morning and the water was scalding hot - we use this shower daily.
I tried the sink and the shower in our other bathroom it was fine.
So my question is do you think the cartridge is gone in the shower?
Any other suggestions?
thanks
Smitty
Smitty1 is offline   Reply With Quote
Old 12-12-2011, 07:33 AM   #2
DIY staff
Rewards Points: 7,174
It would help to know what brand of mixer you have----But---yes--likely failure of the cartridge---
Old 12-12-2011, 07:53 AM   #3
Rewards Points: 14,300
Sounds like the anti scald valve is stuck inside the unit.
Old 12-12-2011, 07:55 AM   #4
Thanks - I am not sure what type of unit it is - I will check when I get home.
Smitty
The Following User Says Thank You to Smitty1 For This Useful Post:
oh'mike (12-12-2011)
Old 12-12-2011, 06:19 PM   #5
Well I went home and took apart the handle assembly - got down to the cartridge - I tried and tried but could not get it out - so I decided to I would put the pin back in and give it a try - well the shower runs perfect - hot and cold and warm....I must have loosened something up when I took it apart.
So I reassembled it and it is back in working order.
Thanks for your help
Smitty
oh'mike (12-13-2011)
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
shower hot then cold then scalding timmdevries General DIY Discussions 7 08-02-2011 10:22 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
