Sanitary Tee On Back For Dry Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2013, 08:52 PM   #1
sanitary tee on back for dry vent
All,
Is it permissible to use a sanitary tee on it's back on a horizontal drain if it is solely for a dry vent only ( no waste ). The horizontal drain is on the second floor starting with the toilet, dry vent, then 2 fixtures downstream on wyes then down to basement (septic).
I would prefer the wye for the vent as well but it is my main stack and there is no room for the wye or combo even when rolling it. The stack continues to the roof.
If it is permissible does anyone know the UPC code to reference to?
Thanks!
kevinrx1 is offline   Reply With Quote
Old 03-11-2013, 09:42 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
Under the IPC no go UPC ? not sure but don't think so, but am sure someone will correct if i am wrong,,, this subject is always coming up
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-11-2013, 09:44 PM   #3
Rewards Points: 1,950
Under the IPC it is OK as long as your vent from the tee does not go horizontal until it is a min. of 6 inches above the flood level rim of the fixture your venting.
Old 03-11-2013, 09:46 PM   #4
Rewards Points: 636
our inspectors says yes it is allowed for dry vent
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-11-2013, 09:48 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 674
If the tee is part of the drain line itself then typically the answer is no. But it is generally excepted by my inspectors(UPC) as long as the dry vent is vertical and a wye cannot be used due to structural conditions
Old 03-11-2013, 09:50 PM   #6
Plumber
Rewards Points: 674
I think most of the plumbers chimed in on this one
Old 03-11-2013, 09:53 PM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 996
Not sure where you got that info but its not allowed under the IPC. the only time we can use a sanitary on its back is when circuit venting, now that being said some inspectors will let it ride if your not VTR its a field inspectors call. however i will look it up under the IPC ..here in Florida we also have to use the Florida building code that covers sections the IPC leaves open, under the Florida building code absolutely to sanitary on its back regardless
Installing a gable vent..from *inside* the attic steveKane Building & Construction 8 12-09-2012 02:45 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 10:40 PM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 12:01 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
