-   -   sanitary tee on back for dry vent (http://www.diychatroom.com/f7/sanitary-tee-back-dry-vent-174231/)
kevinrx1 03-11-2013 08:52 PM
All,
Is it permissible to use a sanitary tee on it's back on a horizontal drain if it is solely for a dry vent only ( no waste ). The horizontal drain is on the second floor starting with the toilet, dry vent, then 2 fixtures downstream on wyes then down to basement (septic).
I would prefer the wye for the vent as well but it is my main stack and there is no room for the wye or combo even when rolling it. The stack continues to the roof.
If it is permissible does anyone know the UPC code to reference to?
Thanks!
Javiles 03-11-2013 09:42 PM
Under the IPC no go UPC ? not sure but don't think so, but am sure someone will correct if i am wrong,,, this subject is always coming up
Ghostmaker 03-11-2013 09:44 PM
Under the IPC it is OK as long as your vent from the tee does not go horizontal until it is a min. of 6 inches above the flood level rim of the fixture your venting.
jaydevries 03-11-2013 09:46 PM
our inspectors says yes it is allowed for dry vent
TheEplumber 03-11-2013 09:48 PM
199 Attachment(s)
If the tee is part of the drain line itself then typically the answer is no. But it is generally excepted by my inspectors(UPC) as long as the dry vent is vertical and a wye cannot be used due to structural conditions
TheEplumber 03-11-2013 09:50 PM
199 Attachment(s)
I think most of the plumbers chimed in on this one :thumbsup:
Javiles 03-11-2013 09:53 PM
Not sure where you got that info but its not allowed under the IPC. the only time we can use a sanitary on its back is when circuit venting, now that being said some inspectors will let it ride if your not VTR its a field inspectors call. however i will look it up under the IPC ..here in Florida we also have to use the Florida building code that covers sections the IPC leaves open, under the Florida building code absolutely to sanitary on its back regardless
