Sanitary T And Cleanout - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-30-2013, 12:19 AM   #1
Rewards Points: 16
Sanitary t and cleanout
Does a sanitary t for a bathroom sink have to be separate from the clean out? In other words, can I use a sanitary t with two sides, one for sink drain and the other for clean out?
Or are two separate t's required?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 01-30-2013, 12:54 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 354
I believe you're referring to a cross? It would be unconventional, but would work. Usually a co tee is installed. If the plumber stuck his cable in the back side of the cross, he may end up sending it across the tee and coming out the sink- not a pretty sight....
The Following User Says Thank You to TheEplumber For This Useful Post:
digitalplumber (01-30-2013)
Sewer Cleanout Replacement SER56 Plumbing 2 12-20-2012 08:19 AM
New construction outside kitchen cleanout blocked off? markbair Plumbing 0 08-05-2012 11:26 PM
Sewer cleanout - which side of trap? Ultrarunner2017 Plumbing 4 08-29-2011 09:56 AM
drain cleanout accessibility options acerunner Plumbing 14 07-07-2010 01:28 AM
Re-using a drain cleanout mpt1123 Plumbing 0 01-19-2010 06:45 AM
