Sanitary Drainage In The U.S. - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-03-2011, 08:52 AM   #1
sanitary drainage in the U.S.
Hi,
As my user name would suggest, I'm from Australia, and from a few of the things that I've read and posted, some of the standards and practices between Australia and the U.S. differ.
From what I've seen in reading some of the posts here and elsewhere, I've only been able to identify two types of sanitary drainage systems used in the U.S. (fully vented and fully vented modified). I was just curious as to whether single-stack and single-stack modified were also used?
Thanks.
aussie steve is offline   Reply With Quote
Old 07-03-2011, 10:16 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
Can you define those terms?
Old 07-04-2011, 08:45 AM   #3
Yeah sure, this comes straight from the glossary of terms.
Fully vented system
A system of sanitary plumbing with provision for the separate ventilation of every fixture trap connected (other than fixtures discharging to a floor waste gully) and of the trap of every floor waste gully
Fully vented modified system
A system of sanitary plumbing differing from a fully vented system, in that the traps of any group of two or more fixtures, or floor waste gullies, discharging to the same branch pipe are vented in common by one or more group vents.
Single stack system
A system of sanitary plumbing in which the stack and discharge pipes also serve as vent pipes.
Single stack modified
A system of sanitary plumbing differing from a single stack system, in that additional venting is provided therin by means of a relief vent, which is interconnected with the stack, at intervals, by means of cross-vents.
I have posted examples of the fully vented modified system, the single stack system and the single stack modified system.
Thanks.
sanitary drainage in the U.S.-scan00022.jpg   sanitary drainage in the U.S.-scan00033.jpg   sanitary drainage in the U.S.-scan00044.jpg
Old 07-04-2011, 09:44 AM   #4
Plumber
Rewards Points: 904
i'm sure you realize there are more then one approved plumbing code in the U.S. I can only speak in regards to the Uniform Plumbing Code (UPC). Within that code we have provisions for combination waste and vents, and wet venting. Comb. w & v is an engineered system usually reserved for large floor areas such as food stores when venting floor drains individually is not practical. So the horizontal drain size is increased to allow for trap venting.
We also have vertical wet venting. This is only allowed for 1 floor (per stack) and a max. 6ft elevation. The drainage fixture load per fixture is also limited.
I can't speak for the IPC but I'm under the impression they are more flexible when it comes to W & V piping.
The first job I apprenticed (a long time ago) on was a 20 story bldg. I can still remember packing cast iron pipe and fittings, wondering if it was all needed. I can see your system cuts out a lot of vent work.
Foundation Drainage bhry Building & Construction 3 09-23-2010 10:08 AM
Pool Surround Drainage Questions Ynot General DIY Discussions 3 06-07-2010 03:53 PM
The IPGC Drainage Pipe agster97 Landscaping & Lawn Care 0 07-09-2009 12:05 AM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 01:22 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
