Old 05-20-2012, 09:28 AM   #1
Saniflo Toilet Tank
I removed my saniflo toilet to do some work in the bathroom. While the toilet was removed my son pushed it over and broke the tank. Is it possible to find a tank that will work with the saniflo bowl or do i need to order a replacement tank from a saniflo distributor?
gilbo125 is offline   Reply With Quote
Old 05-20-2012, 10:36 AM   #2
MarginallyQualified
Saniflo Toilet Tank
On Monday you might find a saniflo wholesaler with a tank that'll match. Or...
In less than an hour you go to the supply house (or even Lowes) to get a NEW toilet.
Another hour and it's installed.
Old 05-20-2012, 10:43 AM   #3
Saniflo Toilet Tank
A new toilet wouldn't work. It needs to be a rear discharging toilet and I doubt you could find one of those at HD or Lowes.
Old 05-20-2012, 12:55 PM   #4
Saniflo Toilet Tank
The easiest(maybe not cheapest or quickest) way is to get exact same tank from saniflo. If you could find a tank with same center to center on tank to bowl bolts, it would probably work. It also depends on what the old flush valve looks like/how far it extends out the bottom of the tank and big or small tank to bowl gasket.
broox is offline   Reply With Quote
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Toilet Tank Won't Empty ihatemytoilet Plumbing 5 11-10-2011 02:24 PM
Toilet Tank Leaking RMCarner Plumbing 17 10-13-2011 08:07 PM
Setting a Toilet tank against a tiled wall jibanez Plumbing 3 01-17-2009 08:54 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
