Old 06-07-2010, 09:25 AM   #1
Saniflo toilet bowl water level
I've just installed a Saniflo Sanibest pump/toilet unit. The unit works great, but the one complaint I have is, after using the toilet there is always is a "bit of a mess" that sticks to the bowl even after flushing. I believe this is caused because the water level in the bowl is quite a bit lower than a regular toilet. Anyone else experiencing this, or have a solution? Can I adjust the water level in the bowl?
vtboy51 is offline   Reply With Quote
Old 06-07-2010, 01:03 PM   #2
A "Handy Husband"
rjniles's Avatar
Skid marks" is a common complaint of these units. Some of the Saniflows have a larger water pool are and this helps. I have never seen any instructions on a way to adjust the level.
Coastal South Carolina
Old 06-29-2010, 09:33 AM   #3
I have experienced the same issue with my Saniflo system I installed last year in the basement. The system works great, with the exception of the "bit of mess" left behind. I have found that a few flushes takes care of things, but we've had to just clean/scrub the toilet more routinely than a normal toilet.
seismic744 is offline   Reply With Quote
Toilet tank to bowl issue. Possibly defective batch? Dr_Jim Plumbing 0 01-18-2010 06:44 PM
water level in toilet toolbelt Tina Plumbing 8 05-30-2009 06:01 PM
No Water entering toilet bowl mjarema414 Plumbing 5 05-03-2009 02:39 PM
Water Noise = Leaky Toilet? DIY_JC Plumbing 5 07-31-2008 07:35 PM
toilet bowl water level problem? darsunt Plumbing 3 08-26-2007 02:10 AM
