-   -   Saniflo toilet bowl water level (http://www.diychatroom.com/f7/saniflo-toilet-bowl-water-level-73042/)
vtboy51 06-07-2010 09:25 AM
I've just installed a Saniflo Sanibest pump/toilet unit. The unit works great, but the one complaint I have is, after using the toilet there is always is a "bit of a mess" that sticks to the bowl even after flushing. I believe this is caused because the water level in the bowl is quite a bit lower than a regular toilet. Anyone else experiencing this, or have a solution? Can I adjust the water level in the bowl?
rjniles 06-07-2010 01:03 PM
Skid marks" is a common complaint of these units. Some of the Saniflows have a larger water pool are and this helps. I have never seen any instructions on a way to adjust the level.
seismic744 06-29-2010 09:33 AM
I have experienced the same issue with my Saniflo system I installed last year in the basement. The system works great, with the exception of the "bit of mess" left behind. I have found that a few flushes takes care of things, but we've had to just clean/scrub the toilet more routinely than a normal toilet.
