#1 |
saniflo extention pipe
I have installed the saniflo system but now I am second guessing myself. The extention pipe from the toilet is butted up againts the macerating unit opening and connected via the acordian gasket. was the pipe suposed to fit inside the opening of the unit? I cant remember if I even tried it. Also the pipe is about 1/4" off center. do you think that is a problem. Im a little concernd with solids being hung up.
Hope I explained my situation well enough. Jesse. |
#3 |
i am somebody but i do not know and the instruction are generic. i personally think it is fine the rubber boot i believe is for vibration isolation
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are 1 poop needs to flow down hill. 2 hot on left cold on right 3 i get a pay check on Mondays 4 do not chew finger nails at or after work. |
| Display Modes | |
| Working with B-Vent pipe for WH vent | BobN | HVAC | 16 | 01-26-2012 12:58 AM |
| Best way to join Poly pipe, for a water pipe repair. | carl1864 | Plumbing | 9 | 08-21-2011 03:17 PM |
| Qs about the 1/2"dia brass pipe we bought | smoochas | Plumbing | 10 | 02-21-2011 10:23 AM |
| What’s the best way to remove pipe from T | Jaylyn | Plumbing | 2 | 02-03-2011 02:05 AM |
| Backpitched Cast Iron Pipe in Basement....uggh.. | apunaha23 | Plumbing | 5 | 02-02-2011 02:42 AM |
